Discussing want to know what rear end in the Classic Mustangs Forum. have a 66 its a one Leger right now staying with stock motor should i ...
Old July 22nd, 2008, 11:54 PM   #1
have a 66 its a one Leger right now staying with stock motor should i just have my stock rear end built or is there a cheaper way to go will a rear end out of a fox body work is there a lot of mods that needs to be done only having one tire smoking just sucks
Old July 23rd, 2008, 09:11 AM   #2
what size rear is in your car now?
i sixing 200 six with 300 hp.
Old July 23rd, 2008, 10:18 AM   #3
Undisputed Champion of MM
Vinyl66's Avatar
1966 Vinyl Mustang
i think im going to throw 4.11's on my 66 w/ stock c4 tranny
Pittsburgh Steelers/Penguins/Pirates FTMFW!!
1966 Ford Mustang w/ Black Vinyl top
Mods listed in Garage
Old July 23rd, 2008, 10:38 AM   #4
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
If you have sucky tires, you could have 2 smoking.
if you are using a 8" rear end and you plan to build no more than 350 horses.
I would just rebuild what you have unless you a free 8.8 rear end laying around.
This is one of many ways to fix your current rear end.
Good Luck
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old July 23rd, 2008, 10:40 AM   #5
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
If you have a overdrive system, Sounds like no problem.
But if not???
My 3:55 Gears are turn my motor over at 65 MPH @ 4000 RPMs
www.Mustang1.Com
Old July 23rd, 2008, 08:42 PM   #6
not sure what size is in there now just really wanted to koow if a rear end out of a fox body 8.8 would fit
Old July 23rd, 2008, 10:01 PM   #7
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
8.8 will not just bolt in. You would have to fix the mount from your 8" to the 8.8"
But anything can be done. "if you have the experience or Money to do it"
We put a total IRS from a 2003 Cobra into a 1967 Fastback.
Like I said Anything can be done.
www.Mustang1.Com
Old July 23rd, 2008, 11:20 PM   #8
so if i build up my 8 inch how much money i am i looking at about 1000 and what about going with a 9 inch is it worth the extra money might put a intake heads and carb on the stock motor but not much Else so a 8 inch with good parts should be just fine and where would be a good place to get the parts
Old July 24th, 2008, 12:46 AM   #9
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
If you are just running a 289/302 you dont need to go to a 9" Rear end.
A Posi is about $400, the rebuild kit is about $120.
I just put a Edelbrock RPM Perfomer intake.
600 CFM holly carb.
Get the parts a Jegs.com Great Price , Great Return policy
www.Mustang1.Com
Old July 24th, 2008, 09:34 AM   #10
i put a lock right unit #1810-lr in my 66 with a 4-11 gear.under 600.00
Old July 25th, 2008, 01:55 AM   #11
brummettx's Avatar
1967 Mustang Coupe
Building her still...
I was just curious as to how you could tell the difference between a 8 and 9 inch rear end? Cause I'm not sure what's in my 67 sorry to change the subject sort of...
Old July 25th, 2008, 10:21 AM   #12
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
Here is a Link,
www.Mustang1.Com
Threads Similar to: want to know what rear end
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 13 October 20th, 2008 03:29 PM
Still Don't know about rear end scxc15 V6 Mustangs 16 December 27th, 2007 08:03 PM
rear end help workinprogress 2.3 Mustangs 2 December 27th, 2007 01:26 PM
99-04 8.8 rear end bloo4.6 For Sale 5 May 13th, 2007 04:13 AM
8.8 rear end Danderson V6 Mustangs 10 April 18th, 2007 03:22 PM
