Discussing Help I need Traction in the Classic Mustangs Forum. Ok here is what I have, Motor: 427W Stroker 486HP / 487 Torque TCI C4 2400 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
June 08 ROTM
1968 GT 500 Super Snake
12.6 @ 114.3
Motor: 427W Stroker 486HP / 487 Torque TCI C4 2400 RPM TCI Stall converter 9" Rear End 31 Spline 3:55 Gears, Spooled Cal Tracs with the rear pinion angle at 5 degrees Nitto NT555R 245/45/17 extreme drag radial Tires. What is going on, Any time I go full throttle It just spins the tires, at any speed. I have to roll in very slow and feather the throttle to keep it from spinning at any Speed. The tires clear the fender by 1/16" and clear the leaf springs by a 1/2" Is there anything else im missing? |
91 Sonic Blue Goodness
19.83 @ 12mph
stiffer suspension perhaps.
Undisputed Champion of MM
1966 Vinyl Mustang
lower gear ratio? of use a fender flare to get larger tires under that beast
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in Garage |
1969 Mustang Mach 1
OLDNSLO
Too much torque
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
June 08 ROTM
12.6 @ 114.3
The Rear Leafs are 4 1/2 mid eye leaf springs. has 2" wheel flairs now...
KYB Shocks. What I am looking at doing is putting 3:25 Gears in it. |
1965 Coupe
4 link suspension?
Stick a spare tire in the trunk?
1969 Mustang Mach 1
OLDNSLO
VHT is your friend. Just give them a good soaking every night...... lol
1979 mustang 5.0
hopefully 11's when complete
i think some bigger tires are in need......... either that or you can put weight in the trunk
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
weight ?
i sixing 200 six with 300 hp. |
June 08 ROTM
12.6 @ 114.3
I would Love to put bigger tires on it. If I Could.
Adding Weight is Like taking Horse power away. ![]() IDK if I want to do that. Last edited by MustangOne : July 25th, 2008 at 07:13 PM. |
1965 Coupe
well, it'll help put the power to the ground, 400hp at the ground is better than 400hp up in smoke
what good is unhooked hp?i hope you find the problem.even with a set of M.T.s i had problems.had to drop a few rpm comeing out.
June 08 ROTM
12.6 @ 114.3
I found Some Help... VHT !!!!
Only Took 4, 55 Gallon Drums ![]()
#14 | |
1969 Mustang Mach 1
OLDNSLO
June 08 ROTM
12.6 @ 114.3
It is Funny how VHT Works.
1969 Mustang Mach 1
OLDNSLO
Yup. They're much better about track prep up there a TRP. Thunder Valley hasn't heard of it, and it sucks.
June 08 ROTM
12.6 @ 114.3
You have to come up and do a test and tune with us.
We are going to get a group of about 4 of us and go play, about the 3rd friday of Sept. |
1969 Mustang Mach 1
OLDNSLO
Just let me know and if I'm free, I'll come up. I probably won't run mine becuase it's slower the Mr. frostys ice cream truck, and it doesn't have an overflow tank, so it won't pass tech, but I'll come hang out.
Threads Similar to: Help I need Traction
| Traction | 88gt1320 | Drag | 7 | June 20th, 2008 04:59 PM |
| Traction help! | cammed281 | 99-04 | 6 | June 25th, 2007 09:12 AM |
| traction on take off | 07stanggt | 2005+ | 2 | May 9th, 2007 11:05 AM |
| Traction | silver99gt | 99-04 | 12 | May 4th, 2007 04:24 AM |
| Traction | wagwjjr | Suspension | 6 | November 12th, 2006 10:32 AM |
