Discussing water in oil ?? in the Classic Mustangs Forum. is there any way to get moisture in the oil besides the intake gaskets, such ...
Old July 25th, 2008, 01:22 PM   #1
water in oil ??
is there any way to get moisture in the oil besides the intake gaskets, such as the water pump bolts, engine is a early 302 with no temp issues just a bit of moisture in the breather caps, compression is fine as is the oil pressure and water in rad is clean.
Old July 25th, 2008, 03:00 PM   #2
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
Head Gasket, Crack in the head/Block.
Is the oil getting milky looking?
When you have about a pint of water in the oil it looks like chocolat milk.
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old July 25th, 2008, 03:54 PM   #3
100% with mustangone plus timeing cover gasket.
i sixing 200 six with 300 hp.
Threads Similar to: water in oil ??
oil and water gauges!! gtdan 96-98 18 May 20th, 2008 06:32 PM
Aftermarket Oil/Water Gauge Install GTPONY1 2005+ 4 January 19th, 2008 04:33 PM
Oil/Water Separator? 2006greyGT 2005+ 11 January 9th, 2008 08:04 PM
Water Temp & Oil Pressure gotboost562 5.0 Mustangs 1 September 4th, 2007 11:50 PM
oil and water sensors rondaw3g0410 Electronics 2 August 26th, 2006 05:27 PM
