Discussing Tach question again in the Classic Mustangs Forum. After checking the Tachmans website it appears that i have to much resistance, could some ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Tach question again
After checking the Tachmans website it appears that i have to much resistance, could some one tell me if the PINK wire going from the switch to the tach is a resistance wire, this is a 67 with factory tach and if this pink wire is indeed a resistance type wire and the coil is also the 1.5 ohm (which it is} then i would have double inline resisters and the tach would read half scale which is what it is doing.
Is anyone else using a petronixs ignition with a factory tach, if so what type of coil are you using?? |
June 08 ROTM
1968 GT 500 Super Snake
12.6 @ 114.3
Yes the pink wire is your resistor wire. The coils should have no resistance.
Just be careful with what you are doing. Everything your talking about cost a little bit of money. Yes I have a 1967 with a factory tach with Pertronics. Mine works I have a 1966 with a rally pac with pertronics, works also. |
Thanks for the info, are you also using a petronixs coil, if so which one?
June 08 ROTM
12.6 @ 114.3
I am use a stock type of coil, no Resistor
Threads Similar to: Tach question again
| Tach Question | Kenn | Classic Mustangs | 1 | July 25th, 2008 02:56 PM |
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 19th, 2008 12:35 AM |
| '06 S197 GT Tach Install Question | Windveil Blues | Electronics | 0 | April 19th, 2008 12:28 AM |
| Tach mount in 72 dash question | Mach1460 | Classic Mustangs | 1 | March 11th, 2007 04:00 PM |
| I have a question on installing a tach | ocsailor86 | 96-98 | 3 | February 14th, 2007 04:07 AM |
