rear disk brakes and rear end
Old August 8th, 2008, 05:03 PM   #1
extropy's Avatar
1969 Mustang Mach 1
extropy is on a distinguished road
I just noticed a slow leak coming from the differential on my 69.
As I was planning to replace the rear drums with disk anyway, a friend had suggested that I transplant the entire rear end from a Cougar that came with disks already on it. As I don't know a thing about Cougars, I don't know how realistic of a suggestion this would be. Any thoughts? Better ideas? Would it be better/cheaper to rebuild what I have and get a disk swap kit instead?
Old August 11th, 2008, 09:05 AM   #2
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
i think they had a small lincoln that would work with a few mods.
i sixing 200 six with 300 hp.
Old August 11th, 2008, 10:36 AM   #3
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
you can use any Lincoln LSC or Tunderbird, Cougar or Mustang
You just have to do some work on it.
Here is my 2003 Cobra IFS Rear end we installed
Old August 11th, 2008, 07:41 PM   #4
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
also, mavericks and monarchs will work if i'm not mistaken. . . sry just noticed that you said rear nvm!
The Curse's tranny bleeding like a stuck pig 600 CFM Edelbrock, Hookers, Pertronix dizzy, Accel coil, GT40 heads, 5.0 h.o,Super 44's, SSBC, FRPP 9mm wires
Threads Similar to: rear disk brakes and rear end
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 04:59 PM
fox with rear disk brakes 90 lx notch 5.0 Mustangs 2 June 21st, 2008 11:35 PM
rear disk upgrade in fox ? 92_fox 5.0 Mustangs 0 December 15th, 2006 08:51 PM
4 to 5 lug and rear disk doorvip 5.0 Mustangs 3 November 21st, 2006 11:56 PM
4 To 5 Lug Convertion And Rear Disk doorvip 5.0 Mustangs 0 November 16th, 2006 06:11 PM
