66 mustang cooling and electrical problems
Old August 11th, 2008, 11:56 AM   #1
66gtmustang is on a distinguished road
My mustang is a 1966 with a 289. Recently I added edelbrock performer cylinder heads, a performer plus cam, performer 289 intake manifold, and a performer 600 cfm carb. In addition to this, I had the engine rebuilt and it is bored .060 over. I have a 4 row standard radiator with a fan shroud and a stainless steel flex fan. However, after receiving my car back from the shop, it is running very hot and even overheating. I can't drive it very far. I understand that engines are supposed to run a bit hot when they are rebuilt until they break in but i dont think they are supposed to overheat. Also, recently the amps gauge read all the way at the D mark, then even more recently the amps gauge read all the way at the C mark. This causes my car to stall out and stuff. Does anyone have any advice for these issues?
Old August 11th, 2008, 01:44 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Sorry to hear.
Ok just a few things ,
A 65-66 Radaitor is to small to handle a .060 over motor, But we are here now. I had a .060 1965 Mustang. These are things i did to it. northern Aluminum Radiator, 17" agressive flex fan, 160deg thermastat 3 1/2 fan shroud, water wetter additive, and a 1965 R modal front valance. With these I could drive it in the summer time. But could not drive it in town to long.
Just keep in mind for the others reading this. on a 1965/66 Try to always stay .030 or under. and you will not have this problem.
Old August 11th, 2008, 01:44 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
How hot is it getting? Boring .060 is a lot and is more than likely causing the problem because of the thin cylinder walls. Your best bet will be a good aluminum radiator, and ditch the flex fan for some good electric fans. Be careful getting those heads real hot because they will warp.
The ammeter should not be running on the C, and it could be a voltage reulator problem.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old August 11th, 2008, 01:45 PM   #4
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
Originally Posted by MustangOne View Post
Sorry to hear.
You beat me to it as usual
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old August 11th, 2008, 02:40 PM   #5
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
i would make sure they did not put the head gaskets on wrong.
i sixing 200 six with 300 hp.
Old August 11th, 2008, 05:18 PM   #6
Yeah, I originally did the heads on my own but accidentally put one on backwards so I just took it to a shop to have them do it cause it took me a really long time to do the first time on my own. I will try the new radiator thing and a bigger shroud. Any suggestions on aluminum ones?
Old August 11th, 2008, 05:30 PM   #7
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
This is the one I used.
Click on the photo
Threads Similar to: 66 mustang cooling and electrical problems
please help with electrical problems tacomatom 5.0 Mustangs 3 June 5th, 2008 01:05 AM
ok electrical problems... EscortSportage 5.0 Mustangs 6 April 12th, 2008 09:18 PM
electrical problems racerx 99-04 3 January 10th, 2008 07:03 PM
HELP! electrical problems! fastford3388 5.0 Mustangs 11 April 24th, 2007 12:11 AM
Electrical Problems? imw1984 5.0 Mustangs 2 November 7th, 2006 11:57 PM
