LinkBack (3) | Thread Tools |
#1
engine number
can someone tell me what these numbers mean 9K30 C90E-6015-C
According to my info,
9K30 = Oct 30, 1969 C90E-6015-C = 1969 302 engine |
#3 | |
How do I know what kind of car it came on? |
The "O" designation means Fairlane but it could have come in anything.
#5 | |
usually a "Z" but that isn't always the case. Just because it has a "fairlane" destination doesn't mean Ford wouldn't put it in something else, especially if the assembly plant was a multi-line location
#7 | |
I took my other block to get it rebuilt which I think was a 72' 302 but they gave me this other one out of 69'. So which would you recommend I keep? |
Classic Moderator
What year is your Mustang? What do you want it for? Was your other motor stock in your Mustang?
Ford would put what ever they had in their cars.
Classic Mustangs are the best! Get one. |
Do you need the matching #'d block for your car? If so, I'd go back to the machine shop, explain that to them and have them prep your old block. If not, go with it as the earlier blocks had a higher nickel content and were considered stronger blocks. What they did was instead of fixing your block now, they gave you one they already had done. Now they will repair that one and swap it with the next guy.
#10 | |
Classic Moderator
So, It sounds like you could of got the better end of the deal. Twist 2 Go knows his stuff about motors. I think I would stay with the block you got.
Want did the do to the heads. There is a lot of power to had in the heads. Don't go cheap there.
They put 65' 289 heads with the stock springs and lifters.
Classic Moderator
How much power do you want from your car and how much money do you want to spend? With stock spring you can't really put in a wild cam. The stock valves are to small and bigger ones need to be out in for more horses. The 289 has 2 kind of heads. There is the small chamber heads and the std ones. I like the small chambered ones.
what about these?
C6DE 6015-B |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/8424-engine-number.html
| Ford mótor | This thread | Refback | March 29th, 2011 06:09 PM | |
| Ford mtor | This thread | Refback | February 9th, 2009 12:04 PM | |
| Ford mtor | This thread | Refback | February 9th, 2009 11:40 AM | |
Threads Similar to: engine number
| make me LOL number 3! | HMUSN | The Clubhouse | 97 | September 26th, 2007 12:55 PM |
| engine casting number help | jbolivar | Classic Mustangs | 6 | August 12th, 2007 10:51 AM |
| engine casting number freak-out... help me. | My67_fastback | Classic Mustangs | 1 | December 30th, 2006 09:27 AM |
| PCM Number? | energiesource | 99-04 | 2 | October 13th, 2006 01:39 PM |
| Number of 86 t-top | hopperwsurf | 5.0 Mustangs | 6 | August 3rd, 2006 01:24 AM |
