wireing entire car
LinkBack (1) Thread Tools
Old August 15th, 2008, 06:26 PM   1 links from elsewhere to this Post. Click to view. #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
wireing entire car
Im taking apart my 65 to get it ready for the body shop but i was wondering. Should i do all the wireing before i send it off or after? Or does it really make a difference.
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old August 15th, 2008, 10:46 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
we always do it after, makes a cleaner job. if you are to buying wire , I would buy 66 wiring.
Old August 15th, 2008, 11:18 PM   #3
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
Do it after or they will just have to cover them before painting. I used a "painless wiring" kit when I did mine..
www.1fun4rd.blogspot.com
Old August 15th, 2008, 11:58 PM   #4
1965 Ford Mustang
why the 66 harness?
1965 Mustang
Old August 16th, 2008, 06:59 PM   #5
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
the 1966 harness has the 5 gauges and the emergancy flashers, and if you have a 2 wire heater already there is not big change over. and to rewire entire car is about $700 for everything.
Painless wiring is miss leading. Should be called PAIN IN The A$$ wiring.
Since Mustangs have a really easy wiring set up and is cheap, there is NO need to use a Chevy color coded hot rod setup in a Mustang.
Also if you use a Painintheass wiring no one can work on the wiring behind you.
With the Ford Set up all the wire colors and the connectors are the same as in the service manual.
Old August 16th, 2008, 10:16 PM   #6
1965 Ford Mustang
Ok Thanks for all the info. Im going to use the ford wiring because im not a big fan of the painless system as well and I have johns mustang right by my house with anything I need.
1965 Mustang
Old August 17th, 2008, 12:26 AM   #7
1FUN4RD's Avatar
2007 MUSTANG GT
Originally Posted by MustangOne View Post
the 1966 harness has the 5 gauges and the emergancy flashers, and if you have a 2 wire heater already there is not big change over. and to rewire entire car is about $700 for everything..
I paid 300.00 from painless
[quote=Painless wiring is miss leading. Should be called PAIN IN The A$$ wiring...[/QUOTE] Only when installing.
Originally Posted by Since Mustangs have a really easy wiring set up and is cheap,.[/quote
I think 300 is cheaper than 700.
/QUOTE]
[quote=Also if you use a Painintheass wiring no one can work on the wiring behind you.[/QUOTE]
Not true at all. If they have a 3 grade education and can read, EVERY wire is clearly labled. Anyone can work on them after its installed.
[QUOTE=With the Ford Set up all the wire colors and the connectors are the same as in the service manual.[/quote] If you use painless wireing you wont need a manual. Again every wire is clearly labled about every 12 inches.
When it comes down to it.
It is your choice. Are you trying to keep the car 100% origonal? Then go with the 43 year old wiring technoligy.
If you are not concerned about keeping the wiring stock. Then by all means go with modern tecnoligy & pick the Painless wiring kit. It has highey quality wire & insulation, it has clearly marked what each wire is & it has a larger updated fuse box with plenty of extra slots for adding accesories.
Old August 17th, 2008, 12:47 AM   #8
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
The 43 year wiring Works Great. Takes 1 hour to install everything complete.
It just plugs in. No need to make any connections up.
Painless? The Chevy wire coloring is a big downer.
The Resale value with the Ford wiring will be alot better, People wont think you went Cheap
$300 is still to much to pay for it.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/84696-wireing-entire-car.html
wireing entire car This thread Refback August 15th, 2008 11:03 PM
Threads Similar to: wireing entire car
How much fluid does the entire PS system hold homeboy2kfun V6 Mustangs 0 August 3rd, 2008 04:55 AM
And...the most fucked up movie in my entire life is??? catchtheroadrunner The Clubhouse 11 March 17th, 2008 12:21 AM
fog light wireing hopper 5.0 Mustangs 11 January 30th, 2008 08:53 PM
wireing gauges 01dutchGT 99-04 18 January 21st, 2008 11:54 AM
a/c wireing? solareclpse2000 5.0 Mustangs 0 January 14th, 2007 09:12 PM
