Engine Question
Old August 19th, 2008, 05:33 AM   #1
Kyzl is on a distinguished road
Engine Question
When the Mustang was first equiped with a 302 or 351 engine, what type was generally accepted as a performance motor? in regards to whether it was an edelbrook or windsor or so on and so forth. Any feed back woul'd be greatly appreciated
Old August 19th, 2008, 09:23 AM   #2
1996 ford mustang
theyanks904 is on a distinguished road
#1 this is a v6 forum should post this in the v8 section but w/e
the 302 really dosent make much power untill you bore and stroke it to a 347 of put a power adder on it
the 351 is a very good v8 and theres to diffrent ones a 351 clevlend and a 351 windser
i think the windser is better out of the 2 and the make a shit load of Hp stock just redoing the top of the motor you can get 450+hps
Old August 19th, 2008, 11:32 AM   #3
JMack's Avatar
2000 V-6
JMack is an unknown quantity at this point
The 302 (5.0L) is a very competent engine. Lots of parts for it, and the Small Block of choice for most street Mustangs (1979-1995) and cruisers (1964.5-1973).
The 351 (5.7L) does come in 2 flavours. THe Windsor(351W) and Cleaveland(351C).
The Windsor was built in Windsor, Canada. It is a 90* V-8 small block.
The Cleaveland was built in Cleaveland, Ohio. It is also a 90* V-8 small block.
The true differences are that the 351W shares heads with the 289 and the 302. The 351C has Oval head (similar to a Hemi). This head/intake setup provides less restrictive valving and intake runner path.
The Cleaveland is the "more bang for the buck" stock motor. I don't know about modified 351's, however the Cleaveland was the better motor originally.
There is a variety of aftermarket parts for both, however if you purchase one, make sure you get the right parts as 351C parts will NOT fit 351W motors and vice versa.
Old August 19th, 2008, 04:40 PM   #4
1994 Mustang Coupe
gQQgsJr is on a distinguished road
the cleaveland is not a small block. it is also not considered a big block but it is much larger than windsor. cleavelands are also much more expensive to build. the heads off of a cleavelad will fit on a windsor only if you have the proper intake. you also have to customize the heads a little bit
Old August 20th, 2008, 09:27 AM   #5
JMack's Avatar
2000 V-6
Like I said, the parts from a 351C will not fit on a 351W...
And it is a small block... Just because it is not a standard block (IE the 289 / 302 / 351W) family, will not cause it to loose the small block nomer. Both the Windsor and Cleaveland have a 3.5" stroke on them and therefore are both Small Block Ford motors. 4.0" and higher stroke signifies a Big Block Ford. All of Ford's V-8 motors fall into these categories (except of course the Flat heads, Y motors, etc...)
Old August 20th, 2008, 03:44 PM   #6
1994 Mustang Coupe
357 Clevor Build ford cleveland 351w motors head swap sbf
this is just a website i found and apparently it says you can put 351C heads on a 351W. but only if you have the propr intake and customize the heads a little
Old August 21st, 2008, 02:12 AM   #7
1973 Coupe Mustang
as fast as the restoration is going
Katen will become famous soon enough
Send a message via Yahoo to Katen
it is true you need a special intake or you can use these cheap looking spacers to fit the Cleavland heads on a Windsor block. but the Cleavland engine is harder to build, not much after market stuff in that block. i would say get a 351w an do some upgrades to it should make ya happy
Old August 21st, 2008, 09:10 AM   #8
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
to put c heads on the w engine you do have to modifie and change manifolds,and both are small blocks!!
i sixing 200 six with 300 hp.
Old August 21st, 2008, 11:36 AM   #9
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
lol...somebody said the 351C is "much larger than the windsor."
So one 351 ci engine is larger than another 351ci engine :
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old August 21st, 2008, 04:32 PM   #10
460brevill's Avatar
the heads are largerbut deck says it is a small block.
Old August 21st, 2008, 10:50 PM   #11
supermachone's Avatar
2004 GT
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
depends on which cleveland and which windsor it is whether its "better" the 351 cleveland with the closed 4v heads was a bad ass motor
Old August 21st, 2008, 11:17 PM   #12
2004 GT
the windsor is a small block, the cleveland is a big small block
351 Windsor - 90 degree family
A basic 302 with extended deck height with thicker cylinder walls
Primarily the only interchangeable part are the heads with other small blocks from the 90 degree family.
In 1969, the 351 Windsor reached its' highest horsepower rating of 290 at 5800RPM
351 Cleveland - 335 series family
canted-valve cyclinder heads.
bore and stroke of 4.00 X 3.50.
a light weight block to beat.
one of the most desirable V8 engines Ford had to offer.
a two barrel or four barrel setup.
From 1970 to 1971 the 351 boosted between 250 to 240 horsepower.
Threads Similar to: Engine Question
Engine Question. thewayshemoves 99-04 2 June 25th, 2008 05:45 PM
Engine Question Till 5.0 Mustangs 12 February 9th, 2008 05:10 PM
PI Engine question k3vin 96-98 1 January 5th, 2008 02:22 AM
engine question Drixops V6 Mustangs 10 February 8th, 2007 08:50 PM
Engine Question man_of_war2081 99-04 19 November 16th, 2006 06:56 AM
