LinkBack (1) | Thread Tools |
#1
Directional Light Problem
67 Shelby, directional lights do not have a constant flashing pattern, they will flash fast and then slow and and fast again, i replaced the steering colunm harness and directional switch, and no change, the four way emergency lights work fine so i swapped the flashers with no change!
Any ideas?? |
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
silly question but what kind of bulbs are you using?
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
1157 bulbs from NAPA, brake and parking lights work fine
2008 GTI
14.65 @ 99.83
oh cuz i was gonna say if you had LED's with no resistors that would be it but dang, yeah i dunno man. sorry i could help.
Softcore Porn Enthusiast
You replaced the signal switch...what about the relay?
2005 Colorado LS, Z71 Off Road Package, I5 Vortec, Space Age Plastic Bed-Liner W/Shiny Factory Installed Deep Drop Tool Box, Twin 12 Volt Power Points...In A Whopping 200+ HP Beast.
There are two relays, one for the turn signals and one for the E-Flashers, the flashers work ok so i swapped the two and it made no differance, i am still going to change them both just to rule them out
The speed of the flash is related to the resistance in the circuit.
Like if a front bulb burns out they will flash more rapidly. If the flash rate is changing I would suspect a wiring problem. Check all bulb sockets & connections for corrosion or broken/cracked insulation. Wires can get pinched or partially broken by moving objects in the trunk. |
I assumed the 4 way flashers used the same circuit as the directionals and they work fine, am i correct that they do indeed share the same wiring?
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Hey Kenn,
Is it a Real Shelby with factory sequenchers. and if so does the emergancy flashers work on the rear blink all 6 lights in order? or all 6 at the same time ? |
It is a real Shelby GT500, the directionals were not seqental in 67 they all work at once
Lost in the 60's
12.6 @ 114.3
With all the lights, It will take a heavy duty flasher bulb for a truck with trailer lights.
sounds to me like you have a short somewhere, causing the resistance to drop which makes it flash faster.
sounds to me like you need a 552-hd flasher.
i sixing 200 six with 300 hp. |
Success, replaced boh flashers with heavy duty type and all is well, Thanks for all the replys, you guys rock!!
Lost in the 60's
12.6 @ 114.3
Anytime we can Help, I did learn some thing myself. Thanks
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/85354-directional-light-problem.html
| Directional Light Problem | This thread | Refback | August 23rd, 2008 09:59 AM | |
Threads Similar to: Directional Light Problem
| directional tire? | ricerraper33 | V6 Mustangs | 10 | July 28th, 2008 03:56 PM |
| Tail light problem | SDSpecial | 2005 - 2010 V6 | 5 | June 13th, 2008 12:49 AM |
| head light problem | 98 cobra | 2005 - 2010 | 1 | June 4th, 2008 02:20 PM |
| fog light problem | JASonic | Audio/Video | 3 | May 2nd, 2007 10:32 AM |
| Courtesy light problem... | D-Brow | Audio/Video | 5 | March 14th, 2007 12:14 PM |
