Edelbrock 600CFM
I have a 600CFM on my stock 289 i also have a edelbrock performer on it. When i hit the gas all of a sudden the engine dies. I have a stock fuel pump could this be the problem.
could be that or it could be or there could be sumthing in the line....my friend had a problem like that and there was stuff in the fuel line that was on the carb. and also is it a eletric choke or not...if so check the wires and stuff........let me no if that helps
it's has an electric choke. I'll check the line and see if there is anything blocking the fuel line. Thanks
Classic Moderator
I really don't think its the fuel pump. I would think that its more likely your carb is not set up right for your set up.
Classic Mustangs are the best! Get one. |
1969 Mustang Mach 1
7.324@94.61 N/A
The problem is Edelbrock.
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser |
did the problem only happen after upgrading to a 600 cfm?
TO: Ricers- 1) there's no replacement for displacement 2) my lug nuts require more torque than your engine makes 3) a light car doesn't excuse a weak engine 4) a bottle of pepsi has more liters than your car eating rice builds muscle |
make sure you jet your carb right and make sure your choke is working. let the car idle for 5 minutes then floor the gas. if it doesnt die, you've found your problem, it lies in the choke .
Look Ma! My First Post!
Is the carb new or was it sitting awhile. If it was sitting then the accelerator pump plunger may be bad and not allowing the fuel to spray in when you first hit the gas. A good way to tell is to take the air cleaner off and look down the carb to see if fuel is actually being shot into the engine (the engine does not have to be running to do theis) if it is not then you need to get the carb repaired, if it is then there is a problem somewhere else.
max |
Classic Moderator
That would be a good place to look.
#10 | |
Does it die before or after the secondaries open? Could be running too rich. Also another thought, have you flushed/replaced the gas tank? Sounds stupid but could be filled with crap.
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
DAMN 69fastback!! Your car just made me miss mine ten times more!! Man that's nice!!
The Curse's tranny bleeding like a stuck pig 600 CFM Edelbrock, Hookers, Pertronix dizzy, Accel coil, GT40 heads, 5.0 h.o,Super 44's, SSBC, FRPP 9mm wires
Threads Similar to: Edelbrock 600CFM
| bbk holley and edelbrock | cali 5.0 | 5.0 Mustangs | 19 | October 21st, 2007 12:39 AM |
| bbk and edelbrock | cali 5.0 | General Tech | 0 | October 14th, 2007 11:34 PM |
| Edelbrock Adj. Uppers has anyone used these? | C MY 4D | Parts | 2 | May 21st, 2007 03:41 PM |
