67 mustang wiring issue
Old August 23rd, 2008, 12:20 AM   #1
obake is on a distinguished road
alright here goes on my 67 the majority of the panel lights up the only issue is that the two key components on my dashboard (the speedometer and the gas gauge) remain unlight. any ideas as to why this might be? just fyi this is my first resto.
Old August 23rd, 2008, 12:38 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
The main reason, Light bulbs are burned out.
It is a easy fix. Just follow the speed o cable up and unscrew it.
Then remove the 6 screws holding the panel in.
Unplug the connector.
then the bulbs holders just pop out.
Push in and twist the bulbs and they will just pop out.
The Bulbs are 1895's Just go by a box of them and replace them all.
Old August 23rd, 2008, 02:09 PM   #3
BA Mustang's Avatar
2001 GT
BA Mustang will become famous soon enoughBA Mustang will become famous soon enough
I have a similar problem. I replaced the bulbs and they still don't work. Except all of my gauges don't light up.
Old August 23rd, 2008, 04:52 PM   #4
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
For you, First try twisting the headlight switch knob to the left while the lights are on and see if they are just turned to the dimmer side.
If not, Look atthe little fuse in the fuse panel see if it is blown.
Last is replace the head light switch itself.
Old August 27th, 2008, 04:38 AM   #5
mustang one you have quite simply no lack of good info thanks man
Threads Similar to: 67 mustang wiring issue
wiring issue? BrandonJD25 99-04 0 July 6th, 2008 02:46 PM
mustang issue... v6modder V6 Mustangs 4 March 17th, 2008 08:23 PM
Wiring issue rlb652_674 5.0 Mustangs 3 February 13th, 2008 01:45 AM
need help wiring my mustang indign Audio/Video 16 April 6th, 2007 06:40 PM
2001 V6 Mustang Issue stallion General Tech 2 December 14th, 2006 07:42 PM
