1967 Mustange Coupe, 200i
Banging in my engine
My buddy and I just pulled the transmission on my 67 (automatic, 3 speed, 200 i6) and put it back in. When I turned it on I heard a loud banging noise that varied with the speed of the engine. I could not locate the source, I thought it might have been a rod but its not, and it sounded like it was coming from the back of the engine. I thought it might be something with the transmission. Could the engine's shaft get bent and cause that, or is there something else? I can't figure it out.
sounds like the shield between the engine and the trans is being hit by the flywheel or its bolts.
i sixing 200 six with 300 hp. |
did you remember to tighten the torque converter nuts?
is the flexplate (flywheel) cracked, I have often seen that mistaken for a bad bearing gtss |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Torque converter is, not seated, aligned with the drain plug in a open hole.
those are the 1st two thing I would look at. |
Ok, thanks. That at least gives me a starting point. I'll check it out and keep you posted.
Threads Similar to: Banging in my engine
| banging obama | vfast | The Clubhouse | 1 | April 2nd, 2008 07:48 PM |
| Washed n cleaned engine today.. pics of engine bay. | MustanG_guy17 | The Clubhouse | 40 | January 4th, 2008 10:14 PM |
| 1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? | zygo4406 | 5.0 Mustangs | 10 | June 4th, 2007 05:53 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
| 1980 mercury capri very loud banging from rocker arms | blackdragon | 5.0 Mustangs | 3 | February 1st, 2007 09:46 PM |
