Door alignment and weatherstrip issues
Old August 30th, 2008, 12:07 AM   #1
extropy's Avatar
1969 Mustang Mach 1
extropy is on a distinguished road
Is it normal for aligned doors to be completely thrown off so that they don't even close properly after the weatherstrip is put in, or does that mean the weatherstrip is in wrong somehow?
Doors were lined up with no weatherstrip in them. Now that I put the weatherstrip in, I have to slam them hard to get them to latch at all, and even then, they don't shut properly. Something's obviously very wrong, but I don't know which to blame. Am I going to have to realign the doors after they're finished?
Old September 5th, 2008, 12:01 AM   #2
extropy's Avatar
1969 Mustang Mach 1
Still no ideas or suggestions from anyone yet?
Old September 5th, 2008, 11:27 AM   #3
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
sounds like wrong weatherstrip or installed wrong.
i sixing 200 six with 300 hp.
Old September 5th, 2008, 01:39 PM   #4
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Sounds like it was the hard china weather striping,
not Danial Carpenter Weather striping. It is alot softer Like the ford stuff
The label will say Danial Carpenter and have the 1979 running ponies logo.
We got some of theat China crap once before and did the same thing your talking about, I will never buy anymore of that crap. It is cheap for a reason.
Old September 6th, 2008, 03:12 PM   #5
extropy's Avatar
1969 Mustang Mach 1
Actually, the package does say "Daniel Carpenter". I ordered it from National Parts Depot. Part of the problem seems to be the upper rear section that screws into the door. It's about a 1/4" too small and prevents the strip from meeting the door where it should be glued in. The other problem in the bottom front corner I'm not too sure about yet. I may need to relocate the screw holes for mounting the other end.
Old September 6th, 2008, 05:11 PM   #6
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
Yes you may have to make some changes.
You do have to good stuff.
Threads Similar to: Door alignment and weatherstrip issues
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 12:49 PM
Alignment Off. ModMustang97GT The Clubhouse 16 June 30th, 2008 10:56 PM
Doing your own alignment AndrewA. 99-04 1 June 26th, 2008 03:04 AM
Door Issues Till 5.0 Mustangs 8 February 11th, 2008 01:12 AM
? About Alignment mustang fanatic 2005 - 2010 4 December 17th, 2007 10:34 AM
