Discussing limited slip diff? in the Classic Mustangs Forum. Hi, i have a 67 mustang with a 1970 MEXI. BLOCKTANKED BORED 40 OVER DECKED ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1967 Ford coupe
limited slip diff?
Hi, i have a 67 mustang with a 1970 MEXI. BLOCKTANKED BORED 40 OVER DECKED AND HOINED ROLLER SETUP, LUNATI CAM ,HIGH LIFT RACEING CAM ,WEIAND INTAKE ,ACCEL COIL,REWORKED4V HEADS,HEADERS,650EDELBROCK CARB,VOLICITY STACK,DYNOMAX EXHAUST, fresh rebuit t-10 tranny,stock 8'' rearend, and i was wanting to put a limited slip diff, but i didn't know which brand was the best for this high performance car. Can you help me?
June 08 ROTM
1968 GT 500 Super Snake
12.6 @ 114.3
Click on Photo
![]() This is what I use High horsepower? No problem--put your power to the ground with the help from Moser Engineering. If you are looking for a stronger replacement for your standard differential, Moser Engineering Auburn Pro Series limited slip differentials are the answer. Available for most popular rear differentials, they are designed to provide more torque and faster engagement for controlled power transfer and quicker reaction to changing load conditions. Whether you're building a street vehicle or an all-out race vehicle, these Moser Engineering Auburn Pro Series limited slip differentials add reliability and consistency to your drivetrain. |
1967 Ford coupe
ok, thanks
1965 Coupe
What do you think of this unit, mustangone?
Powertrax 1810-LR - Powertrax Lock-Right Lockers - summitracing.com it's cheaper, but it's more 'off brand' This is probably one of those 'you get what you pay for' things, eh?
A stock Ford 9" traction-loc should work fine.
I believe '68-69 should bolt right in. |
#6 | |
June 08 ROTM
12.6 @ 114.3
90% of All mustang have a Limited Slip Carrier, The lockers are far and few. And 90% of 67/68 had to be a Big Block car to have a 9" That Powertrax 1810-LR Locker should be fine. Just be sure you know how to install it. You have to use your old carrier. The one I use has all new carrier. Last edited by MustangOne : September 7th, 2008 at 01:21 AM. |
Here is a housing only
Here is a complete set up Maybe you could use this? |
put a 1810-lr lock right in it and keep getting up.
i sixing 200 six with 300 hp. |
Threads Similar to: limited slip diff?
| Limited slip | BLOWN89 | 5.0 Mustangs | 21 | February 8th, 2008 11:59 AM |
| Limited slip | 90 Lxer | 5.0 Mustangs | 22 | January 18th, 2008 01:01 AM |
| Is mustang 2005 GT stock limited slip diff or not? | Evilspark | Drivetrain | 1 | September 10th, 2007 03:34 PM |
| Limited slip diff? | energiesource | 99-04 | 6 | January 20th, 2007 03:35 AM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 05:59 PM |
