Question about rebuilt tranny
I have just got finished restoring my mustang and I have a problem. I have had my engine and transmission all rebuilt. My car idles fine whenever it is in park or neutral but after I put it into any gear it puts a load on the engine and kills it. I have already tried to raise the idle speed and that has not worked. I was wondering if it was because I have a rebuilt tranny and it is not broke in. I would appreciate any help I could get.
Most likely a vacuum leak. Check all hoses and around intake & carb mounting.
What trans do you have? AOD & AOD/e need the TV pressure properly adjusted. FMX & I think C4-C6 have vacuum controlled kickdown. Is it connected? Is distributer vacuum advance working properly? Do you have Vacuum assisted power brakes? |
If all of what kobra suggested checks out is possible something got messed up in the rebuild and you have a bind-up issue (two gears applying at the same time) If it just won't idle but moves fine and only has a problem at idle disregard this.
Certified Master Technician Also FORD certified -Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Or, Could be the torque converter
Well thanks for all the input. I fixed the problem. I had to change my dwell and timing because somehow they got changed.
Threads Similar to: Question about rebuilt tranny
| Another tranny question | ByPopularDemand | V6 Mustangs | 7 | July 2nd, 2007 08:40 PM |
