LinkBack (1) | Thread Tools |
#1
Need 351 Cleveland info....
So, I was recently given a 1973 Gran Torino Wagon, that has been sitting in a guys "yard" for 12 years. No rust, no dents, flawless interior, and a 351 Cleveland. Now, I was wondering a few things about the Cleveland. It has the 2bbl carb, which makes it the 2v obviously. But, what is the difference between the 2v and 4v? I know the 4v has bigger valves and ports, but thats it. Anything else? Remember, I'm just here for motor info.
"It's not until you've lost everything, that you're free to do anything"
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
The 2V cleveland is better for daily driving, The heads are good from Idle to 5500
Just remember when buying a 4V intake for the 2V head that you get a 4V intake for a 2V Cleveland. The 4V Heads good for 2500 to 7500 RPM The Cleveland use the same motor mounts and Bell house set as a 289/302/351W So you can use the 289/302 C4 |
So, would having the main bearing caps drilled out for a 4-bolt setup be difficult? Also, when the 2v is uppgraded to a 4bbl intake, and a set of headers w/ 3" exhaust, does it produce desired power?
Lost in the 60's
12.6 @ 114.3
Fords dont need 4 bolt main caps. The crank is very well supported.
3" exhaust would be a waste, 2 1/2" be just fine. You just need to think about what you are trying to build. If you are building a blown alcohol motor we would do alot of thing diffirent. What I think you are trying to do is build a great cruzier with good power that you can drive every day. What we need is Carb 750cfm holly, Intake, Headers, Cam 280/280 .512 110lc, compression 10:1/1 Just need to have a good game plan. Money goes quikly. Good Luck |
351 c
i built a 351 c with 3x2 barrels that does a good job.
i sixing 200 six with 300 hp. |
IF you run 4v heads a set of torque plates is money well spent.
On both 2V & 4V heads
1. Upgrade the valves to 1 piece stainless 2. Hardened seats on the exhaust. 3. 7/16" stud mounted adjustable rockers, guide plates, & hardened push rods. 4. Roller tip rockers are best. 5. Major porting isn't required but clean up the surfaces & casting lines with 80 grit. 6. 4V heads work best with a dual grind cam like Comp Cams XE series or Lunati VooDoo. 7. Get a cam designed to work in the RPM ranges listed by Mustangeone. 8. With the heavy wagon I would build for low end torque. That means 2V heads. EB Performer intake & 650cfm Performer carb. 2V headers & 2 1/5" dual exhaust. Cams - Lunati 7111 or 62502, Comp Cams XE262H or 268H. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/88360-need-351-cleveland-info.html
| Need 351 Cleveland info.... | This thread | Refback | September 11th, 2008 09:57 PM | |
Threads Similar to: Need 351 Cleveland info....
| 351 cleveland | riddlee josh | The Clubhouse | 10 | February 18th, 2008 11:22 AM |
| 351 Cleveland | 1BADSTANG | 5.0 Mustangs | 30 | January 18th, 2008 11:19 PM |
| 98 Mustang With A 351 Cleveland | zrtstang69 | 96-98 | 3 | November 23rd, 2007 02:00 PM |
| 1970 351 cleveland | mattsstang | Classic Mustangs | 8 | January 19th, 2007 10:54 PM |
| 351 cleveland | ih8chevy | 5.0 Mustangs | 15 | December 8th, 2006 03:26 PM |
