302 build
Old September 12th, 2008, 11:39 PM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
302 build
I have a 302 that when i bought it the guy said that it was out of a 68 cop car. Im not sure on the spec but the cam is a pretty big one. The engine was built but his dad and it runs very strong. Has a elderbrock intake and 650 carb. I want to reuild it after the paint job is done. These are my two plans for it and depending on which way i go, i need options for both.
1st- bore it out and stroke it and go all motor with the biggest cam i can have so it can still be driven everyday.
2nd (leaning towards this one)- Put a vintage or paxton supercharger on it and still maybe stroke it at same time.
Now i need to make sure the engine can hold all this seeing as though i dont want to have to take it out more then once. Im not goiing to be doing the work because im not to familiar with the engine work just yet. I mainly want to know what to buy to make it very strong and then ill take to the engine builder to assemble.
Thanks Guys\
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old September 13th, 2008, 12:02 AM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
If you're wanting driveability and as much power as possible, forced induction is the way to go. Making big power with a small motor, and a big cam is tough, and you're walking a fine line with the whole "biggest cam i can have so it can still be driven everyday" idea.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old September 13th, 2008, 12:42 AM   #3
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
You just need to know what you would like to do, Drive, Strip, spin tires, & gas milage
build a good short block. Rods, Pistons, Crank. 9.8:1
Then Look at heads, Start at $400 new heads
Intake $250
Carb $375
that will do alot for you.
Student, Blowers,superchagres, Alot of money.
Look at NOS does the same thing less cost, you can have the extra power when you really need it.
The main thing is what do you want the car to do. Drive 85% Performance 15%.
It it hard making the best of both.
Or you can just go with 427W for $5900
Just things to think about.
Old September 13th, 2008, 08:56 AM   #4
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
build yourself a 347 stroker with good heads,intakeand carb.that should get it moving.just remember to match your cam setup to your trans and rear.all the best parts arnt worth a hoot if they dont work together.
i sixing 200 six with 300 hp.
Threads Similar to: 302 build
302 build? BostonPerformance V6 Mustangs 2 June 15th, 2008 04:19 PM
302 Engine Build Up 93'_GT 5.0 Mustangs 20 April 17th, 2008 03:43 PM
302 Build 83five0 5.0 Mustangs 4 September 30th, 2007 02:17 PM
302 TF engine build shurb125 5.0 Mustangs 12 March 8th, 2007 06:56 PM
Boss 302 Build Up! ken5_0 5.0 Mustangs 9 October 9th, 2006 03:36 AM
