71 mustang with 351C
Old September 15th, 2008, 04:07 PM   #1
stangage's Avatar
stangage is on a distinguished road
I found a 71 with a 351c the whole car is there has rust on it, what would something like this be worth?
"That old Ford sure fast on the draw out run the Chevys and out run the law"
Old September 15th, 2008, 05:16 PM   #2
fairlane_68 will become famous soon enough
If that motor is in running or rebuildable condition, it's worth a nice little chunk. Got a pic of the car? Hard to guestimate the value without a pic.
Old September 15th, 2008, 05:44 PM   #3
Shake N' Bake
supermachone's Avatar
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
i paid 6k for my 72 with a 351c, and yes if the motor is all there and runs, or is fixable, it could be well worth your time and money
do you know if its a 2bbl or 4bbl?
but yes let us see pics
BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1
Old September 16th, 2008, 05:15 PM   #4
stangage's Avatar
here are some pics the owner sent me
71 mustang with 351C-car0908-005.jpg   71 mustang with 351C-car0908-006.jpg   71 mustang with 351C-car0908-007.jpg   71 mustang with 351C-car0908-001.jpg
Old September 16th, 2008, 05:38 PM   #5
If it runs, not a dime over $1500. Not running, $800 tops. That car looks to be salvageable/restorable.
Old September 16th, 2008, 05:45 PM   #6
Shake N' Bake
1984 Corvette
thats pretty rough, looks like everything is there though...maybe 1k in that condition, depends on how bad u want it though and whether u have the money to fix it up or not
Old September 16th, 2008, 05:52 PM   #7
Shake N' Bake
1984 Corvette
that is the cleveland engine though, looks like a 2bbl, still if its the original motor it was rated at 240hp, ur gonna have a lot of work ahead of you, but worth the restore
Old September 16th, 2008, 07:05 PM   #8
stangage's Avatar
she wants 500 for the car with everything so i might just part it out depending on the body and how bad it is, i would like to restore it but i have 3 foxbodys and one 79 ford f150. think that engine would put out good numbers if i rebuilt it and puts some aftermarket parts on it? would it be worth it to rebuild it.
Old September 16th, 2008, 08:52 PM   #9
Shake N' Bake
1984 Corvette
id buy it for the motor alone, i like clevelands and yes with the right set up it can be a mean street machine
Old September 16th, 2008, 09:05 PM   #10
stangage's Avatar
iam tryin to wrap my head around the 351s...is the 2v the same as a 351 w or 351m..? what are the benifits of having a cleavland vice a normal 351? that car should come with a ford 9in? and lastly what tranny did them things come out with...iam a fox guy these are a new world for me. thanks for your help
Old September 16th, 2008, 10:08 PM   #11
Shake N' Bake
1984 Corvette
351 clevelands and 351 windsors are 2 different motors
351w is in the 90 degree engine family along with the 302 boss, its pretty much just a slightly enlarged 302, still a good motor though
the 351 cleveland and the 351 modified are both in the 335 engine family, i dont know much about the 351m's besides they had 2v carbs, cleveland heads, hydraulic lifters, and a cast iron intake manifold
the 351 cleveland had an option of either a 2v or 4v carb, canted-valve cyclinder heads, bore and stroke of 4.00 X 3.50
the 4v heads from these motors are what make them so popular cause they are closed and not to mention huge, measuring 2.19" intake and 1.7n" exhaust
heres a little info from mustangone and kobra killer from a previous 351c thread
"The 2V cleveland is better for daily driving, The heads are good from Idle to 5500
Just remember when buying a 4V intake for the 2V head that you get a 4V intake for a 2V Cleveland.
The 4V Heads good for 2500 to 7500 RPM
The Cleveland use the same motor mounts and Bell house set as a 289/302/351W"
"You just need to think about what you are trying to build.
If you are building a blown alcohol motor we would do alot of thing diffirent.
What I think you are trying to do is build a great cruzier with good power that you can drive every day.
What we need is Carb 750cfm holly, Intake, Headers, Cam 280/280 .512 110lc, compression 10:1/1
Just need to have a good game plan. Money goes quikly."
"On both 2V & 4V heads
1. Upgrade the valves to 1 piece stainless
2. Hardened seats on the exhaust.
3. 7/16" stud mounted adjustable rockers, guide plates, & hardened push rods.
4. Roller tip rockers are best.
5. Major porting isn't required but clean up the surfaces & casting lines with 80 grit.
6. 4V heads work best with a dual grind cam like Comp Cams XE series or Lunati VooDoo.
7. Get a cam designed to work in the RPM ranges listed by Mustangeone.
8. With the heavy wagon I would build for low end torque. That means 2V heads.
EB Performer intake & 650cfm Performer carb. 2V headers & 2 1/5" dual exhaust.
Cams - Lunati 7111 or 62502, Comp Cams XE262H or 268H."
probably a lot to take in right now lol, but def. some good options for these motors, they are fun to work on and can easily produce power
as far as the rear end, it should have the 9"
im not sure of all the tranny options but a few were a c4 auto, c6 auto, 4 speed standard
Old September 16th, 2008, 10:17 PM   #12
$500 for that car, you should jump on it.
Old September 17th, 2008, 12:04 AM   #13
stangage's Avatar
sad to say i think iam gonna pass on it, iam in africa in the military and my dad doesnt have the time to go get it and tear it apart, if it were a 4v i would but the 2v in my area are easy to find. i want the 4v with the 4 bolt main. thank for all the advice though
Old September 17th, 2008, 01:02 AM   #14
Kobra Killer's Avatar
Kobra Killer is on a distinguished road
4 bolt mains are not necessary unless reving over 7000rpm.
2 bolt can be modified to 4 Because the caps & block are the same.
Clevelands Rule
https://home.comcast.net/~jimmiephil...er_project.htm
Old September 17th, 2008, 01:41 AM   #15
stangage's Avatar
how hard is it to modify...tapping and drillin?
Old September 17th, 2008, 09:58 AM   #16
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Im using a 351 4V 4 bolt im my 1969 Fastback, 10.5 car.
Going to use it for the spring season.
Old September 17th, 2008, 12:45 PM   #17
stangage's Avatar
can you buy an aftermarket 351c block..
Old September 17th, 2008, 06:42 PM   #18
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
No, You have to find a M or Q code car to get these motors. Now days it is hard to do.
Old September 17th, 2008, 07:09 PM   #19
stangage's Avatar
so if i get sum 4v heads they wont bolt on a aftermarket boss block?
Old September 17th, 2008, 07:44 PM   #20
Where is the car located?
Threads Similar to: 71 mustang with 351C
351c head ? crowbar73 5.0 Mustangs 9 March 28th, 2008 12:48 PM
351c pettydvm Classic Mustangs 45 February 15th, 2008 10:54 AM
351C rjhurtu 5.0 Mustangs 1 April 9th, 2007 09:12 AM
351c in a 96 v6 possible? 94v6blkndred V6 Mustangs 1 April 8th, 2007 11:43 PM
351c Q's john0315 5.0 Mustangs 3 April 4th, 2007 12:01 AM
