shaking clutch
I recently replaced my clutch in my 1967 mustang and now the clutch shakes like crazy. It only shakes when it's depressed and it is only sometimes. I'm thinking something is wrong with the throw out bearing, any recomendations?
1969 Mustang Mach 1
6.824@101.61
If it's shaking while it's depressed, it's not likely that it's the throwout bearing. If you let out of the pedal a little, does it still shake? I'm thinking your Z bar needs to be adjusted, because the clutch is moving too far out when the pedal is fully depressed.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
sounds like a bad pressure plate.
i sixing 200 six with 300 hp. |
Sounds like a bad engine mount on the driver's side or wheel hop.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS 66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project) 03 Viper, Supercharged |
1969 Mustang Mach 1
6.824@101.61
Wheel hop...LOL
If the clutch is depressed, the car will not be moving. I still say check the adjustment, as there should not be any pressure on the pressure plate either.
he is getting shake whenhe puts pressure on the peddle.pressure plate or throwout bearing.!!!!!!!!!!!
1969 Mustang Mach 1
6.824@101.61
Actually he never states if it's fully depressed or not, so it's hard to determine what it is.
first sentence,omly shakes when clutch is depressed.
Threads Similar to: shaking clutch
| car is shaking?? | cbrown54 | 96-98 | 10 | August 19th, 2008 07:37 AM |
| shaking | mustang1072 | V6 Mustangs | 21 | March 15th, 2008 02:10 PM |
| Something shaking... | 95blackbeauty | 94-95 | 2 | January 29th, 2008 01:43 PM |
| Shaking? | tkwhitestang | 94-95 | 8 | January 6th, 2008 01:04 AM |
| Shaking Problems | garyvang | 5.0 Mustangs | 3 | May 10th, 2006 07:04 PM |
