Rebuilt engine ticking
So I just had my 289 rebuilt about a year ago. Over the weekend I took my mustang for a drive. The engine only has about a 100 miles on it. While i was driving about 50mph all the sudden this ticking noise started. I started loosing power and it was running terrible. I pulled off the road and tried to figure out what it was. It sounds to me like its at the top of the engine. The thing I cant really figure out is that when you speed the engine up it doesnt speed the ticking noise up. I was wondering if someone knows what it is. I was thinking it is either a valve, rocker or pushrod.
1996,mustang
around 5's 0-60
it could be that but also check your injectors injectors make a ticking noise when they are bad, if its efi check the intake , check the valve spring,
oh it might also take a while for the valves to work in bc you might have sticky valves your you have to redo the heads and did u do it yourself?
bbk cai 8.8 373 dual exuast ported heads bored 30 over forge crank aggressive cam minor shit also [SIZE="4"][COLOR="Red"]crew member #1 that loves mods and administrators[/COLOR][/SIZE] |
I had a local rebuild shop redo the engine for me. I really don't know too much about engines. Im not sure how tough it will be for me to fix whatever the problem is, but i hope it is not too bad.
1969 Mustang
N/A
I would say if it has a limited warranty then take it back to the shop and let them look at it.
1969 Mustang Mach 1
6.824@101.61
Injectors? Is it a fuel injected engine?
If it doesn't speed up with RPMs, it's unlikely it's anything in the valvetrain.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1996,mustang
around 5's 0-60
take it back and have them fix it for free
2004 3.9L V6
15.1
The ticking and loss of power sounds as though a rocker may have come loose or a valve spring is weak. I have gone through these problems before so you will need to take it to the shop that rebuilt the engine or take the valve cover off and check it out.
Race what ya Brought
I found what the ticking noise was. A rocker broke in half. I was wondering has anyone else had this problem? I have a friend that has a 67 with a 289 and he said that he broke 4 rocker armsand then finially put roller rockers on. The only thing different about my engine is that i put a cam in it. Could that be the reason that the rocker just snapped? O also the engine shop did not even know what was wrong with it by listening to it. It was a very strange sound so thats why it was hard to explain.
most likely milage on old rockers,.
i sixing 200 six with 300 hp. |
#10 | |
2004 3.9L V6
15.1
2004 3.9L V6
15.1
Well I was correct when thinking it was a rocker arm or valve spring. When you have a power loss like that and a ticking in the top of the motor always look there first. If a valve spring is weak, the only thing you will notice is oil going everywhere. If it ever happens again, pull over immediately, and tow it home.
#12 | |
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
Threads Similar to: Rebuilt engine ticking
| ticking from engine | energiesource | 99-04 | 15 | July 6th, 2008 09:27 AM |
| engine ticking help | 20gtvert03 | 99-04 | 4 | February 20th, 2008 04:14 PM |
| Engine ticking noise | blk01gt | 99-04 | 25 | February 4th, 2008 11:45 AM |
| Rebuilt Engine | oasr87 | V6 Mustangs | 24 | July 7th, 2007 01:56 AM |
| rattling/ticking when starting engine | k0rrupt | V6 Mustangs | 2 | March 10th, 2007 12:11 AM |
