Discussing Need tuning help in the Classic Mustangs Forum. Hey i have 66 mustang and i know nothing about tuning carbs here is the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Need tuning help
Hey i have 66 mustang and i know nothing about tuning carbs here is the problem if i press on the gas hard then let off of it it stalls and dies. Smells to me that it is running a little to rich could it be loading up. If so how do i adjust it. What could be the problems any help would be great. Info on motor i think its a 289 rebuilt not sure what cam but does have 4 barrel holley on it can take pic if need to see what kind or carb
2004 3.9L V6
15.1
You will need to change your jet size to limit the gas flowing into the motor. Holley can be a little difficult to tune but they are one of the best to use.
Race what ya Brought
1969 Mustang Mach 1
OLDNSLO
What size carb? Holleys are by far the easiest carbs to tune. You shouldn't need any bigger than a 600 cfm on a 289.
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
sounds like the power valve diaphram is bad.
i sixing 200 six with 300 hp. |
2004 3.9L V6
15.1
I have used a 750 Holley with a 289 without any trouble. I do not believe that is the problem unless it is a rediculously big carb, like an 850 or something. It should be a combination of jets and squirters, or the ventris, that is causing the to bog when he lets off the gas
2004 3.9L V6
15.1
If it is the power valve there would be some back firing and it would not run well being that the power valve would hinder the entire performance of the vehicle not just a bog when you let off the gas. He may also need to look at his pump cams on the carb as well as the jets and ventris, or squirters.
it isnt bogging it is shutting off and running rich.still sounds like valve.
so sounds to me there is no quick fix i would need to replace the carb or rebuilt it
1967 Mustang Coupe
Just sounds like the carb is running rich and the mixture screw needs to be turned in.
#10 | |
1969 Mustang Mach 1
OLDNSLO
A big misconception about carbs, is that the small screws on either side are "mixture screws," when they are actually idle air controls. The correct way to adjust the mixture is to re-jet the carb.
so whats the best way to know what jets i need is there a number on the ones that in there or a way to tell if they are diffrent
1969 Mustang
N/A
My car has a 2bbl 500cfm racing carb and it had set up for at least 2yrs before i put it on but I adjusted it by listening to it.I dont have a timing light or a tach but i think I got it pretty dam close cause i can hit tha throtle on tha carb and let go and it wont bogg down or die. Onlt thing I think you should do is if you have a tach then set it at the proper RPMs and adjust the air fuel mixture. It shouldnt be that dam hard but just depends on tha carb.
1969 Mustang Mach 1
OLDNSLO
A timing light has absolutely nothing to do with the carb. Jetting it takes a little practice, but isn't hard.
1969 Mustang
N/A
But if the timing is just slightly off wouldnt adjusting the carb be a little bit difficult?Only reason im asking is cause Im not sure if my cars timing is set right and Ive adjusted the carb and it seems to be ok.
2004 3.9L V6
15.1
Is the carb a double pumper or a quad, because if it is you need to check the jets on the secondaries by the sound of what is happening. You need to check the size and then go down a size or two at a time. It will be trial and error until it is tuned correctly to your needs.
2004 3.9L V6
15.1
The only problem timing may have is back firing or an idle adjustment. I run mine a little retarded. But your carb will use the same amount of gas at a specific rpm no matter what the timing is.
1969 Mustang
N/A
From were it is right now im happy but I thought my motor had a mild cam and it doesnt sound anything like it.No lope. Its smooth.
Threads Similar to: Need tuning help
| tuning | mustangjl | 99-04 | 16 | March 29th, 2008 11:58 PM |
| Tuning... | 2006GTARPD3 | 2005+ | 11 | March 8th, 2008 02:16 PM |
| tuning | dcrow | 99-04 | 14 | September 25th, 2007 11:42 AM |
| Tuning | jjperl | 96-98 | 10 | September 7th, 2007 03:22 PM |
| Tuning help | 94v6blkndred | Engine | 3 | March 19th, 2007 12:34 AM |
