I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
will 77 monarch parts fit a 69 mustang
namely the entire brake system? i found a parts car and yeah info?
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
i have complete 76 granada on my 66.the monark is the same thing.should bolt up.
i sixing 200 six with 300 hp. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
![]() 1969 disc brakes for $525 The kit includes everything needed to swap out your front drum brakes for OE type front disc brakes originally available on 68-73 Mustang. They are technically correct for 70-73 Mustang, but the 68-69 OE differed only in that their spindles have a smaller pin. This kit uses the larger "Boss" type pin used after 1969. Our spindles use the "Granada spec outer tie rod hole. All new parts including high strength alloy steel spindles, a dust shield kit, caliper brackets, corrosion protected calipers, semi-metallic pads, brake hoses, hose brackets and attachment hardware, adjustable proportioning valve, residual pressure valve, master cylinder, master cylinder outlet adapter(s), an adjustable pushrod (manual brake applications), wheel bearings, wheel seals, caliper attachment hardware, wheel attachment hardware, dust caps, performance slotted rotors with bearing races pre installed, outer tie rods correct for your application, Grade 8 attachment bolts, red and blue thread locker, and caliper lube. |
1969 Mustang
N/A
Mustang one has found a dam good kit cause i paid $700 for my convertion kit and it was only stock parts so if you want disc brakes then i would jump on that.
Threads Similar to: will 77 monarch parts fit a 69 mustang
| parts from 96 fit newer?? | 94pacecarSVT | 99-04 | 4 | September 28th, 2008 10:16 PM |
| Will these parts fit? | modded232 | V6 Mustangs | 15 | April 1st, 2008 12:23 PM |
| Pirelli P6 Four Seasons fit on 17x8 mustang rims? 97 mustang | DiegoAlcala | V6 Mustangs | 7 | April 20th, 2007 09:04 PM |
| Do 8.8 suspension parts fit 7.5 rear ends? | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
| So will 05-06 parts fit on a 07 v6? | Scion | V6 Mustangs | 2 | September 8th, 2006 07:42 AM |
