Discussing Shimmy in the rear. in the Classic Mustangs Forum. I have a shimmy in the rear of my 1966 mustang. I do not know ...
Old December 17th, 2006, 06:37 PM   #1
Shimmy in the rear.
I have a shimmy in the rear of my 1966 mustang. I do not know if it is coming from the rear end, or is suspension related. Both rear axles have been replaced using Moser Engineering's replacement axles. New wheels have been added (Edelbrock 454 style) and the car has been lowered approximately 2 inches, using a kit from NPD.
The wheels have been balanced, and alignement is not a problem....since I'm told you cannot align the rear.
Could my drive shaft be unbalanced? A new C4 Stage II Dominator Transmission was installed, could this have something to do with it? I only feel the chimmy over 50 mph, and it is definately coming from the back of the car.
Any ideas would be helpful.
Thanks,
Jeff
Old December 18th, 2006, 06:52 AM   #2
Classic Moderator
Horseshoeing's Avatar
Could be your driveshaft or a u-joint. Have a shop jack up the back end and run it and see where its going on
Classic Mustangs are the best! Get one.
Old December 20th, 2006, 12:19 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
I would start with checking U-joint
Old February 23rd, 2007, 06:54 PM   #4
Lug nuts could be loose. Something loose in the drum brakes. It could be lots of things. "Shimmy" is kinda hard to understand online.
Threads Similar to: Shimmy in the rear.
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 13 October 20th, 2008 03:29 PM
Rear end help... 95blackbeauty 94-95 1 March 8th, 2007 12:36 PM
need 8.8 gt rear end FTHOODV6STANG Want to Buy 2 February 8th, 2007 12:00 AM
Front End, Shimmy Shake tlwoody 94-95 5 November 6th, 2006 03:17 PM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 11:00 PM
