#1 | |
Glorious PC gaming master race
computer nerds HELP!!!
i have no clue wtf is goin on with my xbox
ive google this a few times already and i must be doin somethin wrong im tryin to use my laptop as a router for my 360 but everytime i go to set it up it says its not gettin an ip address from my laptop i had everything set up the other day but now its gone all to shit can someone please walk me thru this?
![]() MILITARY CREW - USAF E-4
01 V6 convertible
too slow to try
you are using wireless to connect your laptop to a wireless router right?
not just plugging in an ethernet cable from the wall then another one from PC to xbox... (which wouldn't make much sense...) |
#3 | |
my laptop is pickin up wireless and i have my xbox hooked up to my laptop via ethernet cable
01 V6 convertible
too slow to try
xp or vista
edit: wait didn't you have a thread like this a few days ago...lol cause this is some dega vu or something |
#5 | |
vista
01 V6 convertible
too slow to try
Guide: Xbox 360 and Windows Vista through ICS - Dev Hardware
^^try that... turn any firewalls off and idk if it would matter, but are you using a crossover ethernet cable? if so try a standard one instead |
1998 Mustang Coupe
Amazing
![]() ![]() iTrader: 2 reviews
i dont know exactly how on vista but here is the gist of it. Ill do a quick runthru on xp.
-go to your network connections -right click on your wireless connection -go to properties -click the advance tab -there should be a box that you can check that says "allow other network users to connect through this computers internet connect" check that box -there should be another box that says "allow other network users to control or disable the shared interenet connection" go ahead and check this too. that should make it work. Another way to do it is -highlight your wireless connection and your local area connection -right click -click bridge connection the problem with connecting to xbox live through a computer is that your NAT setting is a shoot or miss. You cant go set up ports to get an open setting like you can if your xbox is connected directly to the router. this should get you up and going, let me know if it works |
#8 | |
im using the ethernet cable that came with my xbox
how can i tell which kind it is and i did wut that link said and its still not pickin up an ip address
1998 Mustang Coupe
Amazing
the cable that came with your xbox is a crossover and that is the cable type that you need.
#10 | |
ok its still not workin. its recognizing my computer but not the network...
1998 Mustang Coupe
Amazing
hmm, dont know. It is a lot easier when i have the thing in front of me than helping over the internet lol. But im heading to bed, someone else should be able to get you straightened out
#12 | |
thanx raven. im tryin to go thru everything again. hopefully i can get it workin lol
01 V6 convertible
too slow to try
hmmm... never used vista for it, so I'm going around searching...
seems like xbox.com doesn't have any support for using ICS with vista... has everything up to XP... |
#14 | |
i have a feelin im just gonna hafta buy the wireless adapter
01 V6 convertible
too slow to try
there's no way to run a cable to the router?
it'd be cheaper than buying a $100 adapter... |
#16 | |
the router is on the other side of the house...
01 V6 convertible
too slow to try
ok... another thing to try...
skip to page 5... step 8, it'll show you how to get to the IP properties http://www.morrisville.edu/documents...ionsharing.pdf make sure your IP properties window looks like the one on page 7 |
#18 | |
well i never got it figured out so im just gonna go get the wireless adapter
2000 V6
i had had the same problem with my setup. Everything was setup right, but it wouldn't pick up an IP address half the time.It was unstable and unreliable i gave up trying to get it working right and ran a line from the router to the xbox.
Silver Vehicle Club Member #4
Threads Similar to: computer nerds HELP!!!
| Computer Nerds Unite? | silver_fbody | The Clubhouse | 32 | November 20th, 2008 09:52 AM |
| computer nerds unite | White Thunder | The Clubhouse | 7 | October 29th, 2008 04:34 PM |
| hello computer nerds . . . | 707Stang | The Clubhouse | 22 | June 13th, 2008 05:31 PM |
| Where're my Computer nerds? | G.T. Rags | The Clubhouse | 8 | December 24th, 2007 05:08 PM |
| Computer Nerds Might Like This | ChrisJ | The Clubhouse | 71 | November 12th, 2007 12:45 PM |
