Wow, just wow. New clutch is in
Old January 8th, 2009, 02:46 AM   #1
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Wow is all I have to say about it... The difference is night and day. The return on the clutch pedal seems to lag, but I'm sure that will disappear after it breaks in correctly.
Here are pics of the old POS Spec...
There so many hot spots on that damned pressure plate I can't even count em all... The flywheel was just as bad if not worse. Pilcher (the machinist who resurfaced my flywheel) said it was mainly due to the incorrect flywheel job last time AND the massive amounts of chatter and vibration I got out of it. Also the pressure plate diaphram (fingers) the bottom ones were BENT OUTWARD so it made the TOB have an uneven surface to sit on.
Having a transmission jack was so fucking useful that NO MATTER WHAT if I do a clutch on any other car, it will be done on a lift with a transmission jack.
So far I've heat cycled to RAM 3 times now. Just driving it about 15 miles at a time and going through neighborhoods going stop sign to stop sign, then parking her.
I have an exhaust leak on the passenger side header flange Does the gasket go tall side inside the HEADER or the MIDPIPE?
Mods in garage. New mods, new track times soon.
Old January 8th, 2009, 10:31 AM   #2
adrenaline=lifeline's Avatar
13.86@100.3
adrenaline=lifeline is on a distinguished road
bump cause the leaks annoying.........
2004 40th Anniversary GT
Pro 5.0 Shifter
Lowered(H&R Springs)
Summit Hpipe w Dynomax weldin mufflers
Minor odds and ends
Old January 8th, 2009, 12:55 PM   #3
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
ttt
Old January 8th, 2009, 01:00 PM   #4
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
The flat part of the gasket goes towards the manifold and the "raised" part of the gasket goes into the midpipe
Old January 8th, 2009, 01:01 PM   #5
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Thats the way it is and it's a God awful leak...
Old January 8th, 2009, 01:04 PM   #6
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
is it a ford oem gasket?
Old January 8th, 2009, 01:07 PM   #7
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Yeah. I got a few hours today to do it. SO I need to know what exactly to do to get it away... I'm thinking of takiung a shit ton high temp RTV and just plopping it on there.
Old January 8th, 2009, 01:56 PM   #8
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Hmm I put it that way with the ford oem gasket and I'm fine. Im sure your tightening it down tight enough try the high temp rtv too like you said
Old January 8th, 2009, 02:32 PM   #9
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
glad to hear your clutch problem is fixed zinc
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old January 8th, 2009, 03:22 PM   #10
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
I just ripped my midpipe off and worked on it quite a bit. What I did was take high temp RTV and put it around the flange of the midpipe, then took the gasket and put RTV on both sides to create a double sided gasket. I got it as tight as I can with hand tools.
I haven't cranked it yet because I'm gonna let the RTV sit for an hour or two before I give it any heat.
Old January 8th, 2009, 04:38 PM   #11
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
Dylan i'm glad you finally got it fixed man! i'm happy for you i hope this clutch works out!
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old January 9th, 2009, 02:38 AM   #12
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Dude, I could NOT be happier. I gave it half throttle up to 2500 in 2nd gear just to see how it's holding and it's pulling JUST like it should. So far I haven't taken it above 2500-2800ish, put about 57 miles on it and been heat cycling it.
The exhaust leak is ALSO 100% fixed. Now if I could just figure out whats wrong with my cruise control, my car would be 100% perfect again. One could only hope though right?
Old January 9th, 2009, 11:04 AM   #13
03gtfirered's Avatar
2002 MUSTANG GT
14.2@100
03gtfirered is on a distinguished road
how is the intial break in of the RAM compared to the break in of the spec? i am having the same problems with my spec 1 and i want to change it. is there any vibrations in the RAM? is it smooth already after 57 miles? does your TOB sing? my TOB made noise after the first 100miles or so. thanks
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
Old January 9th, 2009, 11:09 AM   #14
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
glad to hear it man...i know we talked about our problems on our clutches.. what you end up getting? and your problem was chattering of the peddal and chirping of the tob..which was from the bent figners? correct??
Old January 9th, 2009, 11:16 AM   #15
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
glad to hear ya like ya new clutch....plus reps because i've never actually gotten to see a used clutch plate...everyone i've had taken out of my cars usually was in pieces.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old January 9th, 2009, 11:25 AM   #16
2002 MUSTANG GT
14.2@100
also did you use the RAM TOB? i think im going to purchase the ram clutch.
Old January 9th, 2009, 05:42 PM   #17
Flynnster's Avatar
2007 Mustang GT
14.70@97.24
Flynnster will become famous soon enough
I believe he did use the RAm tob because it gave him a warranty with the clutch.
Black on Black 5spd '07 GT
FRPP Stingers
Originally Posted by king_Ahmet View Post
] but, if it tickles your sack in a funny way, have at it...
Old January 9th, 2009, 07:28 PM   #18
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
A 1 FULL YEAR warranty.
I bought a RAM OE Stock Replacement for the 2V 01-04 GT/99-01 Cobra from LMR.
Dude. I would reccomend this clutch to ANYONE that has a mild bolt on car. PERIOD. End of story. Spec is garbage. RAM is the way to go PERIOD. I'm using the stock cable and quadrant system as well.
The pedal vibrated on the first drive and that was it, but tha was due to the cable setting in. Right now, I'm letting it cool after another heat cycle. I gave her a littler perk in first gear to see how shes holding up (only to 3000 RPM though) and it's wonderful. No slippage so far and I now have about 74 miles on her.
Old January 9th, 2009, 07:30 PM   #19
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Dude, there was no real break in. No chattering no nothing. It was like it came off the factory line man. Just give it the good 500 miles break in.
I used the RAM TOB. It looked JUST LIKE the Ford OEM one, which if I'm not mistaken, RAM actually makes quite a few of the Ford stock replacement Clutches and Ford will actually put these on and order them for you. Don't quote me though.
Old January 9th, 2009, 07:42 PM   #20
Proud American
MustangMatt96GT's Avatar
gald you got it fixed.... but that flex plate and clutch actually dont look bad at all... my clutch looks a hell of a lot worse and the pressure plate looks similar to yours except much larger hot spots. but my TOB only made noise when in first gear decelerating too...
but i am glad yours is back and running properly... wish my shit would stay together truck and stang included...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Threads Similar to: Wow, just wow. New clutch is in
Wow... XTCNAGT The Clubhouse 3 November 4th, 2008 02:51 PM
Wow this is a first for me TurboLX The Clubhouse 5 August 8th, 2008 03:41 PM
Wow.. so they are making wow easier.. obdnanr The Clubhouse 36 August 5th, 2008 01:58 PM
wow Till The Clubhouse 3 March 27th, 2008 08:26 PM
WOW Twin S/C WOW!!!!!!!!!! dmachine22 Videos 2 April 7th, 2007 02:30 PM
