Questions about squeeks under the hood
Old January 8th, 2009, 02:06 PM   #1
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
When a vehicle is squeeking from under the hood, or squeeling I should say, is this usually a bad belt or is the belt to tight?
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old January 8th, 2009, 04:02 PM   #2
Proud American
MustangMatt96GT's Avatar
too loose IMO
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old January 8th, 2009, 04:10 PM   #3
Moderator
Typically too loose.....like your bungholio
Some symptoms and what I've found them to typically be over the many long years I have trod on this planet.
Squeaks at idle, gets noticeably louder upon acceleration and maintains level of volume increase with rpm increase....may change and go away or diminish as belt warms up and becomes as sticky as your asshole at a pickle party. Belt loose.
Squeaks at idle.....as rpm goes up....never goes away as it warms up....belt looks burnt..possibly idler pulley seizing up or going bad. Like your mom on prom night.
Squeak at idle or as you drive that is intermittent....not too loud...but completely goes away when the hood is open, and can never be duplicated with it open....your hood stoppers are too high or low and dry....sometimes the hood vibrating over the rubber can cause it too squeak....like the gerbil climbing in to your bum. Grease it. The stoppers, not the gerbil. He'll find his way eventually.
Also seen headers squeak when rubbing lightly against something, motor mounts squeaking just before they come apart, and I once had a birdy fly up from the hood when I opened it to see what was going on. Nothing to do here except gaze longingly at your bird is it gets higher and higher.
Then masturbate violently.
Old January 8th, 2009, 07:12 PM   #4
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
That was by far the best response I have ever received to any question I have ever asked in my 30+ years trodding on this planet.......reps.......of course if I have already spread it around enough........my meat of course, not the reps....
BLOWN Bumblebeast!
~Tuned by JJ at WMS
Old January 8th, 2009, 07:17 PM   #5
Moderator
Old January 8th, 2009, 07:31 PM   #6
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
Zip, set a example and stop flaming people.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old January 8th, 2009, 07:38 PM   #7
Moderator
LOL
Old January 8th, 2009, 07:57 PM   #8
jarecis's Avatar
1989 Mustang
jarecis is on a distinguished road
check for this as well
Old January 8th, 2009, 11:09 PM   #9
N29468's Avatar
2004 Mustang
N29468 is a name known to allN29468 is a name known to allN29468 is a name known to allN29468 is a name known to allN29468 is a name known to allN29468 is a name known to all
iTrader: 5 reviews
Send a message via MSN to N29468
dont forget it might be this...
HARDCORE CREW
Mods: Mac Lt's, O/R H pipe, 40's catback, CAI
Originally Posted by 89StangGT View Post
Your not an American if you havn't tongue stabbed a chicks butthole once or twice.
MM DSG Crew Member#4
Old January 8th, 2009, 11:48 PM   #10
Moderator
And this
Old January 9th, 2009, 12:23 AM   #11
tsp_2177's Avatar
2005 Civic
GAY!
tsp_2177 will become famous soon enoughtsp_2177 will become famous soon enough
if my belt squeaks only when the engine is cold and its very humid outside does that mean that it could go soon? o and it stops when i rev a little
but since i have a honda revving a little doesnt mean going any faster lol
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old January 9th, 2009, 12:30 AM   #12
Moderator
It probably means it's just loose, although that usually means that it needs replacing. With the tensioner system on these serpentine belts, they don't need adjusting as in the old days....unless your Honda is super old. If it's adjustable, adjust it.
If it's not, replace the belt. If the belt look burnt or cracked, replace it. Make sure you check both sides of the belt....with the engine off.
The reason it stop squealing when you rev it is because it heats up as it slips and thus becomes more sticky and stops slipping.
Old January 9th, 2009, 12:35 AM   #13
tsp_2177's Avatar
2005 Civic
GAY!
cool thanks man and its an 05 with about 80 thousand on the belt so i'll prolly just replace it soon as well as do a tune up it bogs down bad just giving it moderate gas while its cold
the stangs gone
Threads Similar to: Questions about squeeks under the hood
Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. Chris02 99-04 16 November 1st, 2006 09:46 AM
Shaker Hood Scoop Questions KaZpeR 2005 - 2010 7 October 15th, 2006 07:41 PM
