Glorious PC gaming master race
my xbox
it freezes up everytime i try to play somethin. im not gettin any red rings or anything. any ideas?
King of Clubhouse
overheating
Safud: MM's Resident Hadji
Be prepared to see the red rings VERY soon
Is the game, Ross is the name.
Aids?
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut |
Admanistrator
rrod is cumming soon. get an intercooler
the ic has fans that cool it down, like magic. my xbox is grinding louder than zipee on mso, and ive already had the ring. it sounds like something is wrong with the cd spinner doohicky, but what do yall think it is? |
i have an intercooler and i havent played it all day
how can it be overheating? |
#7 | |
It doesn't have to be on for a long time to overheat...If there is something wrong such as processor shifting, it can overheat even with only 2 minutes of being on. I had one that would overheat and shut off as soon as it would be powered on |
ok. well ill go take off my intercooler and try it again
Admanistrator
how is the intercooler bad? i had it laying around for a while but never used it, then my xbox started freezing and the red ring came, so i turned it off, and the next day i slapped the ic on, and got another month and a half out of it before it completely died. im fairly certain the ic extended its life
Yeah because blowing in dust faster fixes everything
. There is actually a major problem with the IC's...I'm just too lazy to explain it. But to keep it simple...it'll make your xbox's power port go kaboom ![]() The only real fix is to always keep your xbox in a well ventilated area. Also keep your xbox in the horizontal position at all times. Those 2 things alone should decrease the chance of failure by a lot. But gray...once your xbox starts doing what it is now the only (real) fix there is is to get the CPU/GPU reflowed. I'd recommend calling up MS and getting it fixed asap (that is if you have warranty) |
Admanistrator
you're right. incercooler is bad.
The Nyko Intercooler has also been reported to have led to a general hardware failure in a number of consoles, as well as scorching of the power AC input.[23] Microsoft stated that the peripheral drains too much power from the console (the Intercooler power cord is installed between the Xbox 360 power supply and the console itself) and can cause faults to occur, and stated that consoles fitted with the peripheral will have their warranties null and void. Nyko has recently released an updated Intercooler that uses its own power source. Nyko claims this problem no longer occurs with new versions of this cooler. However, Microsoft still considers it an unlicensed add-on and will void the warranty of machines showing signs of its use. There is no data available to indicate whether Intercooler decreases the chance of hardware failure.[23] But if it itself becomes defective it can hinder rather than help the overheating problems. The game console heats up during use, and given enough time, the temperature inside can reach very high levels due to insufficient cooling. An overheated Xbox 360 is indicated by both left quadrants lighting up red. Because of the way the Xbox is constructed, this may result in stresses building up between the delicate ball grid array solder joints of the CPU and GPU and the motherboard, causing them to break. The problem is exacerbated by the specific type of lead-free solder used, a type which is more brittle than the older tin/lead solder that was used in the past and the GPU's location directly underneath the DVD drive. Microsoft needed to make room for the DVD Drive, so they shrunk the heat sink.[24] History of RROD - Planet Xbox 360 Community Forums |
you're fucked... wanna play MK?
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
The IC fucks it up because it pulls power from the sexbox.
I use and have always used a small separate fan and place it on top of my sexbox, and we have a launch unit that still works flawlessly. |
Resident DJ
'01 Cobra Vert.
+1, best way to cool it; keep it out of crammed areas where it can get sufficient airflow and put a mini fan in the back of it.
i actually think its my assassins creed disk. i put in blitz 2 and it worked fine
MM's Database Error
i use a big fan. well used one till i moved into my apartment. then a video card dies...
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
Rebel Of The Sacred Heart
'02 GT
I think Im just going to cut giant holes in the case so it has plenty of ventilation. Or maybe just take the case off all togher so all the heat can escape.
Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed.
#19 | |
), you can watercool the xbox like me
2005 Civic
GAY!
*makes cricket noises*
slow car member twinky times two the stangs gone ![]() ![]() pypes mid muffler catback with their X-pipe In the top 20 cool peoples list on MM potsticker in training |
Threads Similar to: my xbox
| xbox 360 | graystang01 | The Clubhouse | 11 | August 12th, 2008 02:11 AM |
| xbox help | 06RedfireGT | The Clubhouse | 6 | March 12th, 2008 10:47 PM |
| XBOX Live help | 06RedfireGT | The Clubhouse | 21 | January 30th, 2008 12:34 AM |
| xbox 360 | mustang kid 1989 | The Clubhouse | 9 | August 1st, 2007 02:11 PM |
