The Razor's Edge
help with hid kits
this is for the skittle
i got the head lights working with out the relay...need some help getting it in...i will post good pics if needed tomorrow. and the fogs would only flicker... i got one of each of these...the top are for the fog and the bottom for the head lights VVME.COM LLC Your Best HID KIT Supplier i got two of these relays its the top one - The Retrofit Source (U.S.) - HID Projector Retrofit Kits, Retrofit and HID Componenents, Projectors Lens, Wiring Harnesses, Shrouds and more! |
The Razor's Edge
maybe anyone know a shop around va beach that wont charge an arm and a leg
drive up to Winchester VA and Ill help ya.
The Razor's Edge
if only it was closer
With the VVME kits they act funny.. you may have to connect the plug in that goes from the bulb to the ballast upside down. the connector that goes onto the ballast just flip it and thats all you gotta do. umm also you might have to turn your car on, not just on but start your engine then turn on your lights.
![]() JAKE'S PIITB CREW MEMBER#4 |
Oh and you dont need that harness for the VVME kits.. they're just plug n play
#7 | |
The Razor's Edge
Moderator
I looked at it and there are actually 3 different relay's, it looked self explanitory (to me
) but whatever you dont understand just PM me and I can try and explain it more in depth for you
![]() ![]() BUILD 2 IN PROGRESS |
im guessing your fogs come with 10a stock? you can always try a bigger fuse, like a 15, 20, 25.. i wouldnt go much higher than that
Moderator
what amperage is on the relay pack and what amperage are the fogs rated at. you want to be equal to or less then what the amperage is for the fogs. anything more will blow out the fuses to your fogs. dont replace it with a higher one as this can fry out the wire, the bulb, etc... there is a reason why they use a certain amperage
The Razor's Edge
so going with a bigger fuse wouldnt hurt anything...
i was told the relays are nessesary with that kit..... the relays make sence there is just one plug that doesn't... |
what does the plug look like?
The Razor's Edge
im going to have to post pics tomorrow
The Razor's Edge
thanks for the help so far
No problem, but like what wraith said check the amperage on your relay to make sure you wont fry anything
ummm, just putting in a bigger fuse is a bad idea. that is how fires start.
Threads Similar to: help with hid kits
| HID Kits | Blktbss07 | Visual | 15 | October 29th, 2009 05:36 PM |
| Best HID Kits | waswas39 | Visual | 1 | August 14th, 2008 05:06 PM |
| HID kits | whiteboycustom | The Clubhouse | 1 | August 8th, 2008 06:28 PM |
| hid conversion kits | gt500theonlyway | Visual | 2 | January 17th, 2008 06:34 AM |
| HID KITS | myroush6 | 2005 - 2010 | 1 | May 22nd, 2007 09:15 AM |
