c4 flexplate spacer
Old February 4th, 2009, 11:47 PM   #1
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
c4 flexplate spacer
Anyone know where I can find one? I'm trying to find one but having a tough time. I thought I had one but alas I lost it. Help? Reps to those who help a ninja out
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Old February 5th, 2009, 01:47 PM   #2
707Stang's Avatar
2008 GTI
14.65 @ 99.83
Anyone?
Old February 5th, 2009, 02:25 PM   #3
Senor Pointy Boots
atlacatl213's Avatar
2003 Mustang V6
Needs Track Time
atlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to behold
Send a message via AIM to atlacatl213
ATI Flexplates
"Weakness is not your weakness. You are what you grow into..." - Jon Gomm
Old February 5th, 2009, 02:27 PM   #4
1992 Lx
11.39@119.24
Originally Posted by atlacatl213 View Post
ATI Flexplates
ATI flexplates fit aftermarket converters only. Ford Flexplate kits include flexplate, CNC-machined crank piloted spacer and crank bolts. Ford flexplates with 164 teeth have an 11-7/16” bolt circle, and flexplates with 157 teeth have a 10-1/2” bolt circle for Ford converters. Both have factory installed 10-3/4” & 11-1/2” bolt circles for GM converters but only the 10-3/4” bolt circle is usable for the 157 tooth flexplates due to ring gear interference. ATI Ford Flexplates are flat. They will accommodate ONLY converters where the drive pad is ABOVE the converter body
call and ask if you can buy this seperatly
Old February 5th, 2009, 04:03 PM   #5
1973 Coupe Mustang
as fast as the restoration is going
Katen will become famous soon enough
Send a message via Yahoo to Katen
mustang one should have one. i think like decent amount to
Threads Similar to: c4 flexplate spacer
C-4 Flexplate novamastr 5.0 Mustangs 10 January 31st, 2008 02:03 PM
flexplate kreil45 5.0 Mustangs 2 October 31st, 2007 12:46 PM
94-95 AODE Flexplate Specs? Zak 94-95 0 April 22nd, 2007 05:48 PM
Flexplate Difference New88MustangOwner 5.0 Mustangs 2 November 10th, 2006 08:45 AM
