What is acceleration?
Old February 20th, 2009, 04:36 PM   #1
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
the manager of my local Car Quest gave this to my dad the other day. little out of date but still cool...
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the NASCAR Daytona 500. Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. At the stoichiometric 1.7:1 air/fuel mixture of nitro methane the flame front temperature measures 7050 degrees F. Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from the atmospheric water vapor by the searing exhaust gases. Dual magnetos supple 44 amps to each spark plug. This is the output of an arc welder in each cylinder. Spark plug electrodes are totally consumed during one pass. After half-way, the engine is dieseling form compression plus the glow of exhaust valves at 1400 degrees F. At that point the engine can only be shut down by cutting the fuel flow. If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow the cylinder heads off the block in pieces or split the block in half. In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G’s. in order to reach 200 well before half-track, the launch acceleration approaches 8G’s. Dragsters reach over 300 miles per hour before you have completed reading this sentence. Top Fuel Engines turn approximately 540 revolutions from light to light! Including the burnout the engine must only survive 900 revolutions under load. The red-line is actually quite high at 9500 rpm. The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated US $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/2003 Tony Shumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66’ of the run (09/28/2003 Doug Kalitta). Putting all this into perspective: You are driving the average $140,000.00 Lingenfelter “twin-turbo” powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down the quarter mile trip as you pass. You have the advantage of a flying start. You run your ‘Vette hard up through the gears and blast across the starting line and past the starting line and past the dragster at an honest 200 mph. The ‘tree’ goes green for both of you at that moment. The dragster launches and starts after you. He beats you to the finish line, a quarter mile away from where you passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
That, folks, is acceleration.
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Old February 20th, 2009, 04:43 PM   #2
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
re
Cars and mod list in garage
I prefer a girl with a cafina
That's Spanish for vaheena
Which is Italian for clam
Old February 20th, 2009, 04:49 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
nice repost, and the first 5 times it has been posted it was organized a bit better too, like each sentence on its own line not one big paragraph
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old February 20th, 2009, 04:51 PM   #4
ˇʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
re
POST!
Old February 20th, 2009, 04:53 PM   #5
Mod of the Year '11
2021 Mustang V12
Originally Posted by Onemanzu View Post
POST!
you should have said tarded
in all seriousness though, i have enjoyed reading that write up all 18 times it has been posted
Old February 20th, 2009, 04:54 PM   #6
lilmarc1988's Avatar
2001 mustang gt
lilmarc1988 will become famous soon enough
Send a message via AIM to lilmarc1988 Send a message via Yahoo to lilmarc1988
lol
Old February 20th, 2009, 04:57 PM   #7
175lbs of twisted steel and sex appeal
XTCNAGT's Avatar
2007 Mustang GT/CS
XTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of lightXTCNAGT is a glorious beacon of light
Send a message via AIM to XTCNAGT
I think this may have been posted once before...
Originally Posted by 93hatch View Post
the fact that im gay has nothing to do with this thread!
Old February 20th, 2009, 04:59 PM   #8
! Post Entirely Way Too Much
2000 GT Vert
14.646 @ 97.41 2.37 60' Need to hit the track with my new mods
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
never read that before. thats pretty cool.
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
BAMA Performance Drag Team #3
Old February 20th, 2009, 04:59 PM   #9
HBK_2007's Avatar
next year
i dont care if its a repost....still funny
Old February 20th, 2009, 05:47 PM   #10
Trick Tuners's Avatar
KB'd GT
yeah, i've seen that. I like this part
1.5 gallons /sec
4.44 sec / 1/4mi = 6.66 gal
That ends up being 26.6 gallons per mile or 0.038 mpg!
Old February 20th, 2009, 08:44 PM   #11
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
I read that in a car-craft in 1997
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old February 20th, 2009, 08:55 PM   #12
HMUSN's Avatar
iTrader: 9 reviews
acceleration is the rate of change of velocity with time.
ex:
A = lim Δv = dv = d2r
Δt→0 Δt = dt = dt2
Old February 20th, 2009, 09:10 PM   #13
HBK_2007's Avatar
next year
^smartass
Old February 20th, 2009, 09:14 PM   #14
HMUSN's Avatar
iTrader: 9 reviews
Threads Similar to: What is acceleration?
Acceleration issue NYMustang21 V6 Mustangs 41 October 20th, 2008 05:39 PM
Automatic... want more acceleration My First Ride 5.0 Mustangs 61 October 2nd, 2008 11:30 AM
Acceleration HEMENWAY89GT 5.0 Mustangs 4 December 5th, 2007 08:39 AM
Acceleration HEMENWAY89GT 5.0 Mustangs 4 December 3rd, 2007 11:21 PM
want more acceleration!!! 93mustanggtauto 5.0 Mustangs 25 October 16th, 2007 01:15 AM
