03 10th Ani Cobra Vert
12.20@115
Pre-Calc Help
here's the problem if you're up for it... any help is greatly appreciated...
A fisherman leaves his home port and heads in the direction N 70* W. He travels 30 miles and reaches Egg Island. The next day he sails N 10* E for 50 miles., reaching Forest Island. Find the distance between the fishermans's home port and Forrest Islan. Find the bearing from Forrest Island back to his home port. Thanks |
2007 Mustang GT
12.6@110
I'm unfamiliar with the manner you're describing his directions. Clarify if you mean 70 degrees West of North, or 70 degrees North of West. ditto for the N-E direction. This should just be simple vectors though. you've got a triangle of 30 miles and 50 miles, so the hypotenuse is SQRT(30^2+50^2) = 58.31 miles. Once you figure out the angle, you're done.
![]() Professor Crackers
#3 | |
At the Apex pulling 1.2g
I remember pre calc, my teacher was an idiot and I got an A because no one else knew (not even the teacher) what the hell was going on. It was great. AC got it. The angle is a simple inverse tangent function. Make sure to keep the reference correct! |
#4 | |
2011 Mustang GT
12.1 @ 116
That is more of a geomety problem if you ask me.
Mods in garage. Built suspension and gears since posted times. |
im in college calculus and i have no idea... i did jsut fail my test today though
2011 Mustang GT
12.1 @ 116
It's just a triangle.
If you look ati in your head with images, think of a starting point and you go to X at so many degrees, Then you turn (for example sake) right at so many degrees. Based upon those to point that you have reached with those degrees, whatis the remaining side. That's what it seemed like to me
Keep in mind that you cannot use the pythagorean theorem unless it is a right triangle.
#8 | |
Too bad I cant explain it for poo though. |
Assuming you mean 70* west of north and 10* east of north, I got 48.723 miles at 25.35* east of south.
I used law of cosines to get the hypotenuse and the angles... I'd double check my math as I pictured most of it in my head and it could be wrong. edit: actually this is incorrect, I assumed the distance was the hypotenuse of the triangle. I used it as the C in the law of cosines, and since it is not the hypotenuse, it isn't right. Just use an inverse tan like Atlantic Blue said, it'll give you the angle and then you can solve for the length and other angles easily. Last edited by mooses; February 26th, 2009 at 07:15 PM. |
Safud: MM's Resident Hadji
Using a series of right triangles is just a waste of time...This is how it should be done, right triangle = use pythagorean theorem, and all other trianges use sin/cos/tan
1999 Ford Mustang V6
14.79 @ 92.15
It is an inverse tangent function.
#12 | |
2007 Mustang GT
12.6@110
I always sucked at Geometry
12.20@115
Well I got the answer... its not geometry... and its not a right angle... you can only solve right angles using A^2+B^2.... i had to use Law of Cosines and Sines...thanks for all the input guys...
the answers where... Distance: 63 miles Bearing : S 162* E |
Threads Similar to: Pre-Calc Help
| Pre game | gooberhead320 | The Clubhouse | 13 | November 3rd, 2008 05:14 PM |
| Pre-Planning For Suspension | MaverickMLFD371 | 2005 - 2010 | 5 | March 27th, 2008 09:49 AM |
| Pre 99 vs 03 | Bies08 | Racer's Corner | 3 | April 3rd, 2007 04:48 PM |
| Pre 99 Gt's | ESG-642T | V6 Mustangs | 11 | March 20th, 2007 02:13 PM |
| pre painted | droppedbass87 | Visual | 5 | December 30th, 2006 09:41 AM |
