zippeewannabee
Hid Help
got my VVME dual beam hids installed today... and went to go turn them on and nothing..... nothing comes on at all
any suggestions?
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
El Conquistador
do they come on when you turn your high beams on???
do newer mustangs have a daylight running option???? |
El Conquistador
and you cant flash your high beams and lows, thats a good way to burn the bulb and ruin it
double check all the connections too |
#5 | |
Fashion Guru
+1 on connections. don't know what you're talking about flashing the lights. if it would ruin it then why are you able to do it? that doesn't make much sense. but maybe im just not understanding what you said. its been a long day. been up since 4 and didn't go to sleep until 1130 last night |
#6 | |
El Conquistador
and flash them like on and off real fast, click between high and low in a faster then normal pace, turn them on and off on and off on and off really fast.....shit like that yo
zippeewannabee
ya nothing comes on to begin with, so neither the high or low beams work
#8 | |
El Conquistador
did you have to wire anything else???? |
zippeewannabee
nope...
El Conquistador
go take a picture of the ballast and wires
#12 | |
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
What you're thinking of is turning them on and off quickly (or you're thinking about kits that come w/ 1 HID for lows and 1 halogen for highs). Turning HIDs on and off quickly WILL cause them to burn out much faster than they should. To the OP, check your fuses to make sure you didn't short anything. Check to make sure the power wire is secured to the battery. Also double check all the connections to make sure everything is snug.
#13 | |
El Conquistador
zippeewannabee
ok heres what im working with
![]() ground for each side ![]() ![]() main driver side connector ![]() relay ![]() ![]() battery connection ![]() bulb connection ![]()
El Conquistador
ummm....might be a ground issue, try a better place and scrape the paint off
zippeewannabee
it shouldnt matter, it is contacting metal
El Conquistador
no really try a better ground, just because its touching metal doesnt mean its good enough for the lights to come on
zippeewannabee
waiting on this fucking rain
zippeewannabee
ok got them to work finally, but now the common high/low switch is happening
zippeewannabee
anyone know which wires you have to switch when you have the switched high/low beam problem?
Threads Similar to: Hid Help
| HID Help | 00BlueMustang | Audio/Video | 4 | July 29th, 2009 08:30 AM |
| **need HID help** | 02muscle | 99-04 | 4 | June 24th, 2009 06:58 PM |
| HID help | Megawatts88 | Audio/Video | 14 | March 2nd, 2009 12:13 PM |
| HID Help | mantis3567 | 99-04 | 10 | February 15th, 2009 12:27 PM |
| HID help? | energiesource | 99-04 | 3 | June 24th, 2007 01:15 AM |
