Rear end question
Old July 27th, 2009, 07:43 PM   #1
98stangv6's Avatar
1998 Mustang V6 SLOW
17.13@80.85
98stangv6 will become famous soon enough
Send a message via AIM to 98stangv6 Send a message via Yahoo to 98stangv6
Rear end question
Is anyone familiar with the 97's mercury mountaineer? I know this specific one has a 302 and a 8.8 rear end. Would this rear end bolt right up to my mustang or would i have to make some changes in order to make it fit? And what size of gears are in those for that vehicle.
JAKE'S PIITB CREW MEMBER#4
Old July 27th, 2009, 07:45 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Not sure what gears, but I can just about guarantee you'll have to make some changes in the suspension pickup points to make it work under a Mustang.
O o
/¯/______________________
\_\
Old July 27th, 2009, 07:53 PM   #3
98stangv6's Avatar
17.13@80.85
Is that hard to do?
Old July 27th, 2009, 08:41 PM   #4
94bonestocker's Avatar
1983 LX Hatch
94bonestocker is on a distinguished road
Have you tried the tech section? If not there is alot of really good info there. Now if you did and still didn't find anything, read on.
No it will not bolt right up. Even if it did the driveshaft would not as the Exploders have offset center sections. Which is why when the Fox Body guys do a 5-lug swap using Ranger/explorer/aerostar axles they take two axles from a certain side of the vehicle.
Also they have different mounting setups than the mustang.
On my Fox body I'm currently running a Fox Body housing (Turbo-coupe, continental, mark Vii's have the same length housings as the fox body's and sn-95 ((94-98 but I'm not sur on the 99+ housings)) housings) with the Mark Vii axles, disc brakes (front and Rear), calipers, and master cylinder. The S197 Wheels fit perfect on the rear when running this combination. The fronts need a spacer when using the Fox body V8 spindles and A-arms. Eventually I will upgrade to SN-95 Spindels and A-arms to bring the Fronts out more without the use of a spacer.
Is there a specific reason your looking to upgrade to the 8.8?
The reason I ask is if your not running some serious horsepower the 7.5 is just fine. I actually ran one in my car with no problems what-so-ever and I'm running a built 351W. Of course I was running street radials at the time so I couldn't hook up enough to do any real damage.
Just your everyday Non-5.0L LX Fox
Old July 27th, 2009, 08:52 PM   #5
98stangv6's Avatar
17.13@80.85
Im putting a 302 in it sometime, and my friend was going to sell me this 8.8 for $50
Old July 27th, 2009, 08:54 PM   #6
Semper Fi
beefmobile's Avatar
2006 Killer
beefmobile is a jewel in the roughbeefmobile is a jewel in the roughbeefmobile is a jewel in the rough
Rear End??!!
Big Booty Hoes!!!!!!
oh.....wait......
giggadee
USMC CREW
NCMM ORIGINAL CREW
You would think they used camm'd LS1's to launch space shuttles.
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
(Must be 18, void where prohibited, not available in all states, restrictions apply)
Good Night Chesty, Wherever You Are
Old July 27th, 2009, 08:55 PM   #7
1983 LX Hatch
It might have the 31 spline center section which is worth $50 all day long by itself if it's in decent condition.
Basically it isn't worth the hassle trying to get it "Modded" to fit your car. But If I were you, i'd buy it alone just for the 31 Spline LS center section if it has it.
You'd be better off buying the GT-40 Long block off of him if he's selling.
Threads Similar to: Rear end question
rear end question busaonboost 96-98 4 June 10th, 2009 02:55 AM
rear end question AJSTANG 5.0 Mustangs 20 August 21st, 2008 12:50 PM
rear end question SAGE 5.0 Mustangs 8 July 27th, 2008 06:21 PM
Rear end question DSG04GT 99-04 33 March 6th, 2008 09:49 AM
Rear end question Brute448 5.0 Mustangs 2 February 13th, 2007 12:06 PM
