Resident DJ
'01 Cobra Vert.
Simple Math Problem Help
Ok guys, I've had a long day. I'm very frustrated with things right now. I can't get the right answer on this worth shit. I'm usually good with Geometry but I think after doing 2 quizzes this weekend and trying to solve other impossible problems it has made me retarted towards easier problems. If somebody could show me how this gets set-up that'd be great. I know some things but I want to make sure I'm on the right track. Shoot me a PM if you need more questions...
Here's the problem: "Mitchell went into a frame-it-yourself shop. He wanted a frame 3 inches longer than it was wide. The frame he chose extended 1.5 inches beyond the picture on each side. Find the outside dimensions of the frame if the area of the unframed picture is 70 inches squared." So far I have as the width of the outer frame being "X" and the length as "X+3" I have a picture I drew with a box inside a bigger box. (The big, outer box being the frame, and the small, inner box being the picture itself). I have the frame set up to be 1.5" wide on all sides and the area of the picture is 70 inches sq.
1989 Mustang Gt
Run me and find out!!!
the picture is 70 sq. in... the length is 3 units bigger than the width... A = L x W... (so W = L + 3) ; 70 = L x (L+3); 70 = 7 x 10; so the deminsons are 7x10; if the frame is 1.5" past the picture then it is 3 inches wider and longer than the picture... so the deminsions of the frame is 10x13... very simple
Safud: MM's Resident Hadji
PIITB?
So Smart I'm Rotardary!
Ask the frame expert at the shop?
babe, let's get packed
2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
l x w = 70
l = w+3 (w+3) x w = 70 solve for w add 3 for l then add 1.5 to each for final frame
Wicked Topless GT 5-speed Crew
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Troy, sorry bro I haven't been able to get to those problems you sent me. It has been a very, very long day. Again, I am sorry man.
#8 | |
1989 Mustang Gt
2005
^ weems avatar reminds me of
The George Forman of Keepers
if its 70 inches squared...its gotta be 7X10...which just happens to be 3 inches longer on one side than the other. Fancy equations aside.
meh
Tell Mitchell he is an asshole for not giving you simple dimensions in inches.
Ok, your picture surface area is 70 squared, which is 70" x 70"... A=L x W or A=B x H, whichever you prefer. So, the picture must be square... In other words the picture fits perfectly on the top and bottom of the frame, (same height as frame) but the frame is 1.5" wider on the left and right... which makes up your 3 total inches wider. So your 70" x 70" (for the picture) becomes 73"x70" for the perimeter of the frame...
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
#12 | |
Resident DJ
'01 Cobra Vert.
![]() Now this is the only f***er I have left on a different assignment.
#13 | |
Resident DJ
'01 Cobra Vert.
#14 | |
meh
![]() The square of a number is that number multiplied by itself. So 3 squared is 3 x 3, which is 9.... 70" squared is 70" x 70" which is 4900", which would be the surface area of the picture. In this particular problem, however, it does not ask for the surface area of the frame, just the outside dimensions.
Blank
5x14 equals 70 sq inches, so wouldn't the length end up being 8x20 now since the frame is 1.5'' longer on each side, which equals 160 square inches?
#16 | |
ahhhhh...I thought it was 70 square inches. I fail!
Resident DJ
'01 Cobra Vert.
Maybe there's a typo in my professors sheet...because I honestly don't think it's "70 inches sq." It has to be 70 sq. inches. That's the only thing that makes sense to me.
Resident DJ
'01 Cobra Vert.
#19 | |
meh
![]() The problem says nothing about the thickness of the frame itself.... seemed strange they would leave that important part out.
Blank
Ok, I'll explain it in more depth.
5 inches= the width of the picture 14 inches= the length of the picture. The frame is 1.5 inches longer than the picture on each side, so you add 3 inches to both the length and the width right? Or is it just add 1.5 inches to length/width for the frame? If I am correct, then you end up with 8x17. You now add 3 inches to the length because the frame is 3 inches longer than the width, so you end up with 8x20, resulting in an area of 160 square inches. This is my guess.
Threads Similar to: Simple Math Problem Help
| I did the math... | Dansby | The Clubhouse | 11 | April 28th, 2009 01:39 PM |
| The after math....... | Blondie99 | The Clubhouse | 13 | November 24th, 2008 09:38 PM |
| Really need some math help please | 97GT4.6 | The Clubhouse | 9 | August 29th, 2008 02:15 PM |
| Do Some Math | Mach Boy | 4V / SVT | 8 | July 22nd, 2008 01:23 AM |
| Unbelievable Math Problem | Racerchik02 | The Clubhouse | 68 | July 20th, 2007 01:18 PM |
