351 W head identification
Old February 11th, 2007, 02:05 PM   #1
Where's The Post Button?
351confused is on a distinguished road
I am trying to identify my heads for a small block ford. The heads are marked D70EDC and hace holes for emissions in the ends. The head has studs with flat shoulders. How do you identify these?
Old February 11th, 2007, 03:00 PM   #2
mdvaldosta's Avatar
11.47@120.58
I know they're from 1977, that's about it. I'll see if I can find a place that deciphers the rest of it.
Old February 11th, 2007, 05:44 PM   #3
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
According to the engine specs sheet I read off the internet the first 4 numbers break down like this:
D7 means from 1977, O=Fairlane (62-68) or Torino (69-76) ?? E=Engine
DC = I have no idea what this means.
Before 1976, the heads feature larger valves than the early 289/302 and provide a simple bolt-on horsepower upgrade (again for the early 302s I dont know if this is applicable to 302 HO's).
See http://phystutor.tripod.com/stang/engines/small.html
And http://raceabilene.com/kelly/hotrod/engine.html
I am sure there are better sites out there that can tell you more or people around here who know exactly.
Old February 12th, 2007, 07:05 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What size are the head bolt holes? That is the easiest way to identify them and is about the only difference between 351W and 302 heads from the 70s. 351W uses 1/2" bolts and 302s use 7/16 bolts.
Threads Similar to: 351 W head identification
will a 4 plug head replace a 8 plug head CooolCobra 2.3 Mustangs 5 September 19th, 2007 12:12 AM
Lifter tick identification wanabebuff 5.0 Mustangs 15 June 12th, 2007 08:02 PM
Block identification hubba076 99-04 3 May 27th, 2007 03:45 AM
Engine IDentification Cskit1500 5.0 Mustangs 2 December 4th, 2006 02:06 AM
Head studs Vs Head bolts turbong 5.0 Mustangs 2 November 29th, 2006 05:28 PM
