Chemistry/Physics question
Old September 29th, 2009, 11:42 PM   #1
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I was postulating this on the porcelain throne, and I'm trying to figure out where my math is failing:
If I have a 5.0 liter 4-stroke engine, that means that I process 2.5L of air-fuel mixture with every revolution of the motor (assuming 100% volumetric efficiency).
That means that if I'm cruising a 2000 rpm, the motor is processing 5000L of air-fuel mixture every minute. At a stochiometric ratio of 14:1 (I think that's actually lean, but I'm not sure what's ideal), that would mean every liter of air-fuel mixture has 15 "parts" - 14 of air, and 1 of fuel.
If we divide 5000L by 15, we get 333.33 L of fuel consumed in that 1 minute. Converted to gallons (at 3.8L/gallon), that's 87.7 gallons of fuel.
87.7 gallons to drive 1 minute at 2k rpm with a 5.0L engine? Nuh-uh. At the most it should be 0.1 gallons. (assuming 2k rpm is ~60mph, 1 minute of operation should travel 1 mile, and assuming 10mpg).
What's missing here? My immediate assumption is there's some conversion between the volume of gasoline as a liquid and the volume of gasoline as a gas (roughly 900:1 based on the above), but that doesn't make sense - gasoline does NOT exist as a gas inside an internal combustion engine, right? Isn't it just aerosolized liquid?
O o
/¯/______________________
\_\
Old September 30th, 2009, 12:57 AM   #2
Seriously? No responses whatsoever?
Does no one know, or does no one care?
O o
\_\
Old September 30th, 2009, 01:02 AM   #3
Dansby's Avatar
Dansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of light
Send a message via AIM to Dansby
I just don't know...haha. I'm interested to see the correct solution, but I'm an english person, haha.
Old September 30th, 2009, 01:03 AM   #4
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
I may take a stab at it tomorrow....I'm too tired now
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old September 30th, 2009, 01:05 AM   #5
Blank
unlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to behold
I don't know, and I'm sure that's why others have failed to respond. I have looked over your calculations a few times and I don't see what you did wrong to result in that way off answer. You may be onto something concerning a liquid gas to vapor gas conversion.
Old September 30th, 2009, 01:26 AM   #6
MM's Anti-Hardparker
08blkgt500's Avatar
2008 Shelby GT500
08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of
usually im very good with math/conversions and i agree the answer cant be 87.7 gallons. i tried doing it myself, got the same answer. i tracked it backwards on your word problem. all i can say is maybe its not 2.5L of air-fuel mixture per revolution? either that or the stochiometric isnt 14:1?
MM Cobra Club #24
Old September 30th, 2009, 01:37 AM   #7
cusp's Avatar
2008 Mustang GT
cusp is on a distinguished road
Your error is using volume instead of mass. Chemical reactions work on mass.
So you need to take 14 Mol of air and 1 mol of gasoline for your reaction. I don't know the Molecular weight off hand of your elements. But thats the key to getting things to calculate out correctly.
2008 manual GT with deluxe trim, FRPP CAI, FRPP GTB Mufflers & 91 All Out Tillman Tune. 3.73 gears, Coast Ultralight Drive-shaft. 18" OEM Polished Bullitts, Webelectric Sequentials, XM built into the Shaker 500. Alarm and Escort RedLine.
Old September 30th, 2009, 01:45 AM   #8
08blkgt500's Avatar
2008 Shelby GT500
^ that could be it
MM Cobra Club #24
Old September 30th, 2009, 05:59 AM   #9
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
Fuck we just learned about this in Chemistry today... But there's alot of factors involved. and isn't 5.0 the amount of displacement? I would think it would be alot less volume that the mixture is being inserted too
but yeah I'll try again when it's not 5a.m. and I have class in 4 hours
Ideal Chemical equation is something like
2C8H18 + 25O2 -> 18H20 + 16CO2
MM Cobra Club #66
Old September 30th, 2009, 06:31 AM   #10
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
I haven't done this shit in over 15 years, but it seems to me that the parts are wrong. They should be PPM, or parts per million so i dont think taking 5000 and dividing by 15 is right. If you got 87 gals I think it should be something in the range of .087 or so. This would make more sense.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old September 30th, 2009, 12:09 PM   #11
Trick Tuners's Avatar
KB'd GT
you need to use pounds of air and pounds of fuel instead of liters. Stoich is 14.7 not 14.1 (at least for regular gas)
Old October 3rd, 2009, 09:52 PM   #12
cusp's Avatar
2008 Mustang GT
Pounds work.
A mole has 6.0221415×10^23 atoms or molucules and is measured in mass not volume. Boyles law describes the physics of gases. A 5.0L engine is a measure of volume. So depending on things like pressure, (Density Altitude and/or Forced Induction) and Temperature, the mass of air and fuel pumped through that volume will change. Horse power comes from the fuel when it combines with oxygen to release heat. So to get your reaction to come out right, you need to have 14.7 Moles of Oxygen (air is 18 percent O2) and 1 mole of gasoline.
Old October 3rd, 2009, 10:52 PM   #13
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
This is interesting...
Oxygen in the air is what Stoch is based on? Not the entire mass of air in the cylinder before combustion? If its based on weight not volume then you would need a shitload of air to meet the liquid weight of gasoline....and that makes sense when thinking 14:1.
Air weighs 14.7 pounds per square inch at sea level. IDK...Im confused now.
Old October 4th, 2009, 01:26 AM   #14
KB'd GT
haha, no it doesn't! Each breath i take would weight at least 50 lbs!! Its 14.7psi of pressure from all the air in the atmosphere pushing down. So a 302 would spit out 4439lbs of air for 2 revolutions! From a quick search air at STP is about 1300g/M^3. The ECU deals in # of air and # of fuel. MAF measurements are converted to # of fuel and thats why injectors are rated in #/hr instead of a volume. (ricers like CCs)
Old October 4th, 2009, 01:32 AM   #15
the fucks i gave today=0
Dennis's Avatar
Dennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud ofDennis has much to be proud of
am i the only one who got a headache just reading that shit lol
I can shit a human sized target at 15 feet
Old October 4th, 2009, 01:33 AM   #16
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
no.
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old October 4th, 2009, 01:35 AM   #17
aka Nature boy
sickfox's Avatar
I like turtles
2+2=4 4-2=2 2/2=1 1-1=0
www.xjor.org
Old October 4th, 2009, 02:50 AM   #18
cusp's Avatar
2008 Mustang GT
The air column above you exerts a pressure 14.7 PSI during "standard" conditions. But the column extends into space. So in effect that 1 Sq inch is very tall. O2 in the air is what the reaction is based on. The other 82 percent of the gasses to not combust or if some trace molecules happen to, they are in amounts to small to make a difference.
Old October 4th, 2009, 03:21 AM   #19
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
so how much does a cubic foot of air weigh?
Old October 4th, 2009, 10:47 AM   #20
KB'd GT
Link
About 0.075 lbs. Caculated using the ideal gas law: PV=nRT. Assuming the T=68F (528R) and P=1atm with the MW of air approx. 28.8 lb/lb-mole. The gas constant R, using these units is 0.7302. Rearranging the formula to give: mass = MW*(PV/RT)
the air constitution is aproximatly this:
* 75.523% nitrogen
* 23.133% oxygen
* 1.288% argon
* 0.035% carbon dioxide
* 0.001267% neon
* 0.00029% methane
* 0.00033% krypton
* 0.000724% helium
* 0.0000038 % hydrogen
so, the molar mass of the air is the sum of:
N2 = 0.75523 * (2 * 14.0067) = 21.15656008
O2 = 0.23133 * (2 * 15.9994) = 7.402282404
Ar = 0.01288 * 39.9481 = 0.514531528
CO2 = 0.00035 * (12.0108 + (2 * 15.9994)) = 0.01540336
Ne = 0.00001267 * 20.1798 = 2.55678066*10^-4
CH4 = 0.0000029 * (12.0108 + (4 * 1.00795)) = 4.652354*10^-5
Kr = 0.0000033 * 83.7982 = 2.7653406*10^-4
He = 0.00000724 * 4.0026 = 2.8978824*10^-5
H2 = 0.000000038 * (2 * 1.00795) = 7.66042*10^-8
21.15656008 + 7.402282404 + 0.514531528 + 0.01540336 + 2.55678066*10^-4 + 4.652354*10^-5 + 2.7653406*10^-4 + 2.8978824*10^-5 + 7.66042*10^-8
= 29.08938516
Threads Similar to: Chemistry/Physics question
Gasoline Chemistry problem yellowstang6r The Clubhouse 0 September 15th, 2009 10:14 PM
Help with physics winnie51189 The Clubhouse 13 February 13th, 2009 10:30 AM
help with physics? graystang01 The Clubhouse 25 April 18th, 2008 03:02 PM
need idea 4 chemistry project El_Cangri The Clubhouse 4 December 2nd, 2007 04:59 PM
Chemistry... Can Someone Balance This Equation For Me? Triple A The Clubhouse 10 November 13th, 2007 05:47 PM
