#21 |
Safud: MM's Resident Hadji
All these suggestions to open it up and extract drives and whatnot is NOT where the problem lies. You have a corrupt file in your registry...all you need to do is fix that one file. Boot from a live version of linux and you'll have access to all your files without having to open the computer at all. From there you can replace any corrupt file and be on your way
#22 | |
Dancing Naked In The Rain
#23 |
Too Soon, Junior!
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Do what safi suggested first, I'm just assuming hardware failure since you said this happened after the cover was slammed down. My first guess would be that the hard drive skipped on a pin and it scratched the disk.
![]() 03 GT - Scrapes on lane markers - Modded 02 Cougar - Able to clear most speed bumps - Some mods 01 Explorer - Parking blocks NOM NOM NOM - Stock Nitrous Switch Panel for sale! |
#24 |
Here is the download link
Download Ubuntu | Ubuntu Download and burn to a disk. Boot from it, then when you get the option you should be able to choose "Try ubuntu without any changes to your computer" From there you will be able to fix any corruptions you may have |
#25 |
Resident DJ
'01 Cobra Vert.
Sounds like someone brokeatid the harddrive.
#26 |
Getting Laid Is A Bitch
Baker, if you're around the Denham Springs or Baton Rouge area I can take a look at it for you.
![]() Saleen wheels / Front: 255/45/ Rear: 275/40/ Steeda CAI / 93 Perf. Bama tune Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms J&M adj. panhard bar / Camber plates. |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
naw man... im up dare in shreepote. LOL (shreveport)
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
#28 |
From the sounds of it, it's probably the hard drive or a corupted windows files. If the notebook is using a sata hard drive, it will fit into a typical sata desktop pc. From there you should be able to recover files as long as the hard drive isn't bad. Once you've done that, you can attempt to reload windows. If it barfs at you while doing it, it's time for a new drive.
#29 |
04 Mustang GT
Honestly, if I wasn't somewhat knowlegable on computers, most of the above advice would go over my head.
Most do not know what safe mode is, nor do they know what sata means, nor do they know how to diagnose a broken hard drive. Hence the reason for companies like the geek squad. Baker, if you want, pm me your number. I'll try to walk you through some of the basic checks
Military Crew |
#30 | ||
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
Here's a basic idea what you can do to either backup your files or if you can pull that file missing in your Vista CD, you can install it manually in that directory by using Ubuntu. Use Ubuntu Live CD to Backup Files from Your Dead Windows Computer :: the How-To Geek If you get stuck I can help out ^^ Linux FTMFW! Oh and to burn an ISO file just use "burn Image/Project" in whatever burner software you use. should fit a blank CD.
#31 |
Senor Tini
put in your vista disk and select repair windows after you boot to it. it usually will fix it right up.
Threads Similar to: Computer problem..... wont start up....
| Computer wont charge!!!!! | Drick | The Clubhouse | 9 | May 21st, 2009 02:39 PM |
| Computer problems. Wont Boot up | Bill | The Clubhouse | 19 | October 8th, 2007 05:29 PM |
| 96 GT wont start | Mystry | 96-98 | 6 | March 17th, 2007 01:25 PM |
| Hooked up new computer harness and car wont start | Steves LX | 5.0 Mustangs | 3 | December 13th, 2006 08:36 PM |
