05 Busa & 08 R6
faster than a Ford
![]() iTrader: 1 reviews
If heat rises, why is it cold up there?
Ok, so I'm a 5th grade teacher and I don't get stumped too often. But, the other day in class, I had a question that I really couldn't answer! We were talking about hot and cold air and the fact that hot air molecules have more kinetic (movement thus heat) energy than cold air molecules. A girl raised her hand and asked me, "If heat rises, why is it cold in the mountains? Where does the heat go?"
What came to mind was the fact that air is thinner the higher you go. Since the air is thinner, it hold less heat and is colder. That's what i told her, but I said I definately didn't really know. Anybody know?!? Heat rises, but at some point, the higher you go, the colder it is. At what point is that?!? Are you smarter than a 5th grader?!?!
![]() '05 Hayabusa Limited Edition & '08 R6 '04 Skidoo Summit 800 1980 Jeep CJ5 350 MM Cobra Club #30 & 31 (Cobras both sold )My best creation: http://www.youtube.com/watch?v=UxvKUdZpvnU |
The saying "heat rises" is an acknowledgement of the fact that warmer air has a lower density than the surrounding atmosphere, and therefore, being of lower density, it will rise. This rising is limited however - think about it - if there were no limit to hot air rising, then the entire atmosphere would float out into space. The reason it is "cold" in the upper atmosphere is actually because of a lower air density. Remember that our concept of "temperature" as measured by a thermometer is actually the energy of the collisions between atoms. If you have a high density of atoms and you put thermal energy into the system you will raise the temperature. In the upper reaches of the atmosphere, the decreasing density means that even if the temperature were constant, it would FEEL like the temperature was going down. This lowering of temperature with altitude is called the "lapse rate" and a standard lapse rate is about 3deg Fahrenheit per 1000 feet. This can change from 1-5 degrees F depending on variables like pressure, humidity, etc. If you want to learn more about it, search for information on the tropopause.
05 Busa & 08 R6
faster than a Ford
Wow, what do you do for a living?
Fashion Guru
the reason the mountains are cold is because of wind. the wind hits the mountain and goes up. the air is hot and when it rises too quickly is what also gives precipitation.
the reason seattle is mostly rainy. the wind comes off of the ocean and climbs altitude and precipitates. |
175lbs of twisted steel and sex appeal
Magic.
Admanistrator
As you go higher and higher up in the atmosphere, the temperature rises and falls. If at ground level it is 60*, then going up to about 10 miles, the temperature will steadily drop to ~ -80*, but then it starts rising again, and at 50 miles, it will be ~40* and then the temp starts dropping again while the altitude goes to 90 miles, which will be about -120*, and then the temp rises to 120* at about 120miles about the surface of the earth.
This is all b/c of how thick the atmosphere is, and how much solar radiation is absorbed by those atmospheric particles. |
1990 LX hatch
Cause the source of heat is hotter.
Tree Fiddy Z
higher altitude = lower air pressure = lower temperature
HowStuffWorks "Why is it colder at the top of a mountain than it is at sea level?" |
muneris pro ego
Chuck Norris
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
I'm sticking with magic.
Final answer. |
1990 LX hatch
Then why is it colder at the bottom of a body of water?
Because its farther from its heat source.
Golf Pencil Kawk Juggler
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
MM's Resident Muffler Shop
Meine Garage ![]() MAD Stangs #9 Olivia Munn FTW Crew Founder commandersafi (10:54:49 PM): i love how much veiny sticks out |
Threads Similar to: If heat rises, why is it cold up there?
| Heat from down under!! | bamasvtgt | 4V / SVT | 6 | September 16th, 2009 01:47 AM |
| heat? or no heat? | 02gtmustang | 99-04 | 17 | July 16th, 2009 10:44 PM |
| No Heat | JcSurge311 | 5.0 Mustangs | 12 | December 21st, 2007 12:22 PM |
| no heat | hmotes | 5.0 Mustangs | 8 | January 15th, 2007 04:24 PM |
| Please help with the heat | tdurbin | 5.0 Mustangs | 12 | May 19th, 2006 11:15 AM |
