zippeewannabee
track tomorrow, what will she run?
what do you guys think? here is the list of mods from my garage.
AC Miller Built High Comp Shortblock -Romeo Cast iron block bored .020" -5.933" H-beam rods -Diamond Flat top pistons -Stock Stroke 6 bolt GT crank -Clevite Bearings -Total Seal File Fit Rings -SVT 4V Oil Pump and Pickup Induction -Patriot Performance Stage II heads -AC Miller Mod Motor Stage II cams -PI intake -Trick Flow Plenum -BBK 75mm TB -JLT RAI -DynoTune Nitrous Kit w/ 150 shot Exhaust -Hooker Super Comp ceramic coated headers -Hooker 2.5" X-pipe -Magnaflow Catback Fuel system -Ford 39lb. Injectors -Focus Fuel Pump Tune -DiabloSport Chip tune by Josh Levin of Levin Motorsports Suspension -H&R SS Springs Driveline -MGW Short Throw Shifter -Deleted Front Sway Bar -Ford Racing 4.10 Gears Wheels/Tires -FRPP Bullets, 17x9s and 17x10.5s -Nexens up front 315 Nitto 555Rs out back
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
#2 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
11.3
![]() Do you know what the compression is. You said high, but what is high to you? I'm pretty high
id go with 11.8
03 GT: Totaled 2000 Ford F-150 Triton V8:F'd in the A 1999 Plymouth Voyager: The BangBus Topless Mustang Club Member |
#4 | |
the "nitto" part scares me
zippeewannabee
sorry guys i forgot to mention, i will be doing this on motor. im going to try the nitrous, but ive had some problems with it so i cant count on using it. that said, the comp ratio is at about 12:1
#6 | |
N/A 11.8
Juice 11.3 Honestly I have only been to the track once. So I am clearly a professional
Hooo Ha Ha
I say you hit 10s with spray
![]() 374rwhp 456rwtq @ 8psi |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
He won't go 10s. I say 12.40 on motor and 11.70 on spray.
zippeewannabee
thats about what i was thinking. hoping i could get a solid run with the spray, but im not counting on it.
One Man Wolf Pack
You don't have the suspension for a real fast time either way. I say 12.8 on motor and 12.2 with a real high trap on spray.
![]() ΜΟΛΩΝ ΛΑΒΕ
i say 11.9 n/a 11.3 on spray. i think that car could eventually see an 11.0 with seat time.
AKA Greased-up Deaf Guy
2008 Shelby GT500
1.8 seconds, 678 mph
MM Cobra Club #24
#13 | |
It could happen.
A very concentrated micro-burst that goes into his intake with the culmination of 2500 lbs of boost and the wind at his back.
zippeewannabee
thanks guys, ill keep you updated. also with some vids
I Want A Good Speed Raping
Im going to say less then a min. but more then a second.
![]() I have no clue about mods or anything just came to wish you luck good luck man hope you hit 10's altho as i see people dont thing you will.
1992 Lx
11.39@119.24
13.4 on motor. Fuck nittos
#17 | |
Proud American
but i bet 12.8s would be about right on motor and probably a 12.0 on spray with lots of spinning...
zippeewannabee
yea not to sure about the sittos, but i ran a 13.3 without the 4.10s with a 1.9 60ft spinning down the track
07 Turbo Focus
12.93 @ 105mph
This would be my guess.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
i agree with both of these. i was talking to him last night and i figured 12.5@110-111 if he can hook up
Threads Similar to: track tomorrow, what will she run?
| Going to the Track tomorrow | Shaun03GT | 99-04 | 13 | October 31st, 2009 12:10 AM |
| Going to the track tomorrow | BDaily | V6 Mustangs | 7 | August 15th, 2008 03:45 AM |
| please help going to the track tomorrow | cptkng79 | 5.0 Mustangs | 4 | May 24th, 2008 03:47 PM |
| Going to the track tomorrow | ujslost | 96-98 | 5 | March 25th, 2007 02:32 AM |
| First Run Tomorrow! | Tony_90fox | 5.0 Mustangs | 4 | October 14th, 2006 04:55 AM |
