Hip Hop Artist
Byebye V6~
Welcome Home New Pony :P
Ceiling Lighting Help!!!
Okay... electrical = not my thing..
anyways went to home depot bought one of those ceiling lighting things.. worker there gave me wrong bulbs.. no sweat went back to exchange.. connected everything and it wont turn on lol.. im no genius but i always thought BLACK wire was ground.. so i grounded the black wire to some green bolt that connects to the board.. and connected the white wire to my power cord... and nothing.. i dont know what im doing wrong ... Lithonia Lighting 4 Ft. Strip 2-Bulb 40 Watt T12 Fluorescent Fixture - C 2 40 120 MBE 2INKO at The Home Depot its that so if anyone can help.. Thanks
![]() ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig http://www.myspace.com/moddedmustangz Modded Mustang's Song
One Man Wolf Pack
No, the black wire is the hot supply wire.
You connect white to white, black to black and the ground wire to the green bolt.
![]() ΜΟΛΩΝ ΛΑΒΕ
Hip Hop Artist
Byebye V6~
okay there is only 2 wires though.. 1 black 1 white .. the rest are already connected to the ends of where the bulb go.
even on the back of the box it saids connect white with white black with black.. but theres only 1 black 1 white lol
Getting Laid Is A Bitch
There should only be one white and one black wire, black being hot, and a plain copper wire for ground. If the fan doesn't have a ground, take that puppy back and grab one that does unless you like blowing bulbs.
![]() Saleen wheels / Front: 255/45/ Rear: 275/40/ Steeda CAI / 93 Perf. Bama tune Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms J&M adj. panhard bar / Camber plates. |
95 GT, 06 vert v6
havent ran
not all new devices have a ground... white to white black to black... with plasic boxes and plastic conduit being used so much now you see the ground becoming a thing of the past
![]() 1995 GT - Light Mods (getting more fun!!) 2006 Vert V6 - This is for the wife! she loves it! Northeast Ohio |
Hip Hop Artist
Byebye V6~
okay im gonna try grounding the white then
Hip Hop Artist
Byebye V6~
okay thats not it lol... my power plug just xploded and took the rest of the power down lol.. it melted a bit lol
#8 | |
![]() ...and because I'm your friend here, don't die, or catch fire.
Hip Hop Artist
Byebye V6~
i got shocked once when i was in 5th grade lol.. i started yelling and my teacher gave me detention.. ftmfl...dont fuck around with the pencil sharpner when your tryna plug it in lol
its really simple actually i can get pictures but i dont have a camera so ill have to do it with my phone.. theres a ballast with most of the wires connected already.. 1 black wire and 1 white wire arent.. i noticed there wasnt a power plug so i asked homedepot they just told me to cut an cord extension and twist the copper together then put electrical tape.. ive juggled white with the extension and black.. the white actually melted the power end a bit lol
meh
So let me get this straight. You have a fluorescent light that you want to be able to plug into a regular 110v wall socket. Am I right?
The light should have 1 white wire and 1 black wire that are bare on the end. It may have a green wire, it may have a green screw on the frame, and it may not. Black is hot, white is neutral, and green (or bare wire with no sheathing) is ground. ![]()
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
#11 | |
Hip Hop Artist
Byebye V6~
i did that but there is no green wire. only a green screw. i tried grounding the black wire then the white wire and it exploded my wall lol.. also lost power for a bit. the plug kinda melted too =T so what your saying is i just need a wire to go from the ground to the power?
meh
NO!
If you have a 3 prong cord, (like a 3 prong extension cord) there will be 3 wires in it. A black, a white, and a green. If you look close at the male plug on the 3 prong cord: The black wire goes to the flat narrow prong. The white wire goes to the flat wide prong. The green wire goes to the round prong. You need to get your 3 prong extension cord, cut it to your desired length. Then look at the wires: tie the white wire from the cord to the white wire on the light fixture, tie the black wire from the cord to the black wire on the light fixture, and take the green wire from the cord and screw it down to the light fixture with the green screw. Read this and refer to the picture I posted.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 Last edited by Notcho; June 15th, 2010 at 06:54 PM. |
One Man Wolf Pack
Just connect the black to black, and white to white and put a wire nut on the ground wire and tape it up real good so that it can't come in contact with any of the other wires.
![]() ΜΟΛΩΝ ΛΑΒΕ
Glorious PC gaming master race
hire an electrician before you die
#15 | |
Hip Hop Artist
Byebye V6~
the power cord i had to get was actually a power cord extension i had to cut and split.
Don't die lol, thats all I got left. I've done wiring many times among other household things but this is just..... get help man lol
Hip Hop Artist
Byebye V6~
ive been through to much to die from this measly thing!!
ahh screw it.. ill buy a premade kit lol
#18 | |
One Man Wolf Pack
What I said should still apply.
![]() ΜΟΛΩΝ ΛΑΒΕ
Hip Hop Artist
Byebye V6~
thats the thing bro. there is no ground wire lol. only 2 wires that arent hooked up. 1 black 1 white.
MM's Database Error
why dont you take pics of what you have and post them up...that might make it a little easier
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
Threads Similar to: Ceiling Lighting Help!!!
| ceiling fan help | Breakout | The Clubhouse | 41 | May 3rd, 2010 03:35 PM |
| Ceiling Cat... | futureMACH1racer | The Clubhouse | 9 | September 15th, 2009 03:54 PM |
| Lighting strike | WAR-PARTY | The Clubhouse | 7 | August 2nd, 2008 02:04 AM |
| freind got a lighting... | DeMello | The Clubhouse | 89 | July 4th, 2008 02:45 PM |
| Lighting | VaporS197 | 2005 - 2010 | 33 | December 6th, 2007 10:21 AM |
