Altacat linux thunderbird halp
Old December 18th, 2010, 12:29 PM   #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I am using mint and trying to install thunderbird
I get ubuntuzilla installed without any errors and I open the terminal and type "ubuntuzilla.py" in the terminal and I get this
Code:
Retrieving the version of the latest release of Firefox from the Mozilla website...
Traceback (most recent call last):
  File "/usr/local/bin/ubuntuzilla.py", line 1331, in <module>
    bs.start()
  File "/usr/local/bin/ubuntuzilla.py", line 311, in start
    fi.start()
  File "/usr/local/bin/ubuntuzilla.py", line 354, in start
    self.install()
  File "/usr/local/bin/ubuntuzilla.py", line 764, in install
    self.getLatestVersion()
  File "/usr/local/bin/ubuntuzilla.py", line 956, in getLatestVersion
    self.releaseVersion = re.search(r'firefox\-(([0-9]+\.)+[0-9]+)',self.releaseVersion).group(1)
AttributeError: 'NoneType' object has no attribute 'group'
How the fuck do you install this piece of shit?
Following this site
http://ubuntu-install.blogspot.com/2...untuzilla.html
I also tried to follow another write up that was poorly done. Dude was all over the place.
http://www.theinquirer.net/inquirer/...nderbird-linux
Old December 18th, 2010, 12:35 PM   #2
Senor Pointy Boots
atlacatl213's Avatar
2003 Mustang V6
Needs Track Time
atlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to behold
Send a message via AIM to atlacatl213
Ahhh I don't think you need to do the whole python thingy.
make sure all your software sources are open to the multiverse and universe and so on... In terminal do this...
sudo apt-get update && sudo aptitude install mozilla-thunderbird
you don't need to use ubuntuzilla on mint 9 since most software packages are already in the repositories unlike regular ubuntu.
"Weakness is not your weakness. You are what you grow into..." - Jon Gomm
Old December 18th, 2010, 12:39 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
Jesus why the hell do people make it so fucking hard?
Someone rape him for me, I have to spread it around. One fucking sentence and it's done
Old December 18th, 2010, 12:42 PM   #4
Holy Dick Castle!
dr.gonzo!'s Avatar
Now If I can get my native resolution to work
TV native resolution is 1360x768 but when I put it on that it is too damn big for the screen.
Got any magic commands for that?
Old December 18th, 2010, 12:46 PM   #5
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
ehhhh resolutions huh? lemme see here. I know in Ubuntu you go to system > preferences > display and you should play with those settings there. Are you talking about a screen resolution that doesn't show up in those options?
Old December 18th, 2010, 12:51 PM   #6
Holy Dick Castle!
dr.gonzo!'s Avatar
When I click on that it forwards me to use my GTX260 graphics card tools and by default it is set to auto which is really huge. Like 800x600 would be on a windows machine just a little wider in the text. When I take it off auto and select 1360x768 it is too wide for my TV and I have tried to shrink it down with all my TV settings and still can not get it to fit on the screen.
Old December 18th, 2010, 01:01 PM   #7
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
hmmm well sheit. I guess you can go at it of one of two ways...
Assuming you have an Nvidia card, you might want to get it configured to the best drivers/settings.
Read this carefully:
Mint 9 = Ubuntu 10.04
https://help.ubuntu.com/community/Bi...erHowto/Nvidia
Or....
If you know what resolutions and refresh rates your video card and monitor/tv are capable of, you could try this.
http://ubuntuforums.org/showthread.php?t=1246309
I have not done it myself, but I must say that thread on with extreme caution, you could eff something up and have to redo everything
Old December 18th, 2010, 01:24 PM   #8
Holy Dick Castle!
dr.gonzo!'s Avatar
I found a driver that works but it says I have x-config running. Is there a way you can run mint at the command prompt before it loads the GUI OS? I know in back track you could type commands before it loaded and the command to actually start the GUI was "startx"
Old December 18th, 2010, 01:55 PM   #9
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
hmmm I guess if you want to try that you'd probably have to reboot the computer, get into grub menu and go into recovery mode kernel option thingy and boot into terminal as the options state there.
I believe you can get to your grub by holding down the shift key before it loads the OS.
edit:
you'll be brought into this screen
then you can choose root with shell prompt
Old December 18th, 2010, 02:16 PM   #10
Holy Dick Castle!
dr.gonzo!'s Avatar
Blahhh the build in driver says I had the last updated supported driver. I noticed in the monitor type, it has my LCD TV as a CRT monitor with no options to change it. I will stick with a little blurry 1152x864 for now. I think it either has to do with
not being able to change to LCD monitor cause the nvidia setup in windows let me choose tv, crt or lcd.
or its a freaking unchangeable overscan issue with an older cheap vizio TV.
Old December 18th, 2010, 02:33 PM   #11
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
Hmmm either way, I suppose that this would be beyond my ability to help, gomenasai.
Old December 18th, 2010, 02:41 PM   #12
Holy Dick Castle!
dr.gonzo!'s Avatar
Yeah man andreagassi, right back at cha
Tanks a lot
Old December 18th, 2010, 02:51 PM   #13
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
Tanks a lot
nani? wakarimasen...
No problem
Old December 18th, 2010, 02:55 PM   #14
Holy Dick Castle!
dr.gonzo!'s Avatar
Andre Agassi
Old December 18th, 2010, 03:05 PM   #15
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
ohhhh!!! ohh.... o.o
Threads Similar to: Altacat linux thunderbird halp
Halp! More gif hunting... Iconoclast107 The Clubhouse 8 May 24th, 2010 09:07 PM
Linux people halp. dr.gonzo! The Clubhouse 3 January 20th, 2010 09:44 AM
Need Halp Fast! armymike63b 4V / SVT 7 April 19th, 2008 01:04 PM
