01
AR15 Ammo vs barrel twist
Educate me.
Suppose i have a 1/7 twist barrel on a mid-length 16" Upper w/ Daniel Defense M4 12.0 Rail Which of these are better for this specific barrel? The heavier 62 gr? Federal .223 (5.56) 62grn M855 20rd Box or the 55 gr? Federal .223 XM193 55grn 20rd Box I think i remember hearing that 1/7 twist is better for stabilizing heavier grain bullets. Is this correct, in that case i'd buy the first one, which is 62 gr? or is 62 gr still considered light? I know that running lighter bullets in a 1/7 will tear them apart in the air, but assuming that heavier ammunition costs more, is a 1:7 twist upper really worth it? Assuming that the heavier the bullet, the better it will be stabilized past 100 yards, i might as well compromise with the 62 gr ammunition rather than the 55 grain.
![]() Last edited by Imran; February 15th, 2011 at 02:12 AM. |
01
are PMAG's really worth the premium over steel GI mags?
#3 | |
Resident Bubblehead
Random Shemale Nudity FTW
2007 Mustang GT
https://www.libertygunsupply.com/Pro...040701&click=2
H&K. I will never use any other brand mag The Marines on our boat last deployment turned me onto these guys (got 8 for free WOO!) They go out and buy these and use them over their standard issue ones. To each his own but for me, I will never use anything else.
Somebody call for a really hairy plumber? Bow chicka bow wow! I came here to lay down some pipe. Bow chicka bow wow! So, I hear you have sisters. Bow chicka-who are twins-wow wow!
94 Eaton V6
You want to go with a lower grain when using a lower twist rate. I use a 55 grain for the 1/9 twist upper and 70+ grain for the 1/12 twist.
It seems to work well for my setups. This book was helpful as well, Justin |
Resident Bubblehead
I'm pretty sure no one makes a 1/12 barrel for a 5.56/.223 AR, at least not anymore.. 1/12 is pretty common for 6.8mm and .308 Win. chambered AR's Most modern AR barrels in 5.56mm/ .223 will be 1/7, 1/8 or 1/9...
Resident Bubblehead
Jakashh, check this out. I tried to find a good write up on m4carbine.net, but I couldn't, so I had to go to ar15.com. This should answer your questions on twist rates...
I Do Not Prefer Semen!
2000 GT
slower than fish stix
dpms makes alot with 1/12. atleast they used to. you def. need to use something a litle heavier with a 1/7. my DDXV had a 1/7.
Resident Bubblehead
Yeah, most of what's available nowadays is 1/7, 1/8, 1/9, I wasn't aware that anyone still made bbls in that twist rate. I know when the M16 was first issued, it had a 1/14 bbl for the 55gr ammo in use at the time. This was changed to 1/12 for increased stablity in cold weather. I've just never come across anything modern with a 1/12 twist rate in 5.56/223. My AR has a 1/7 bbl...
2000 GT
yeah now that i think about it, it seams like most of the basic dpms are 1/9. i wish i never sold my daniel deffense
At the Apex pulling 1.2g
With a 1:7 twist rate, you will probably want to stick to some of the heavier rounds for use. I've read (meaning I've never had it happen
) that some 55grain rounds with enough powder out of a long enough barrel cause the rounds to fly apart. That said, a 1:7 should be great for launching the heavier rounds with great accuracy. You'll have to see when you go to the range which your gun likes best, but I bet the heavier will fly better out of your barrel than the lighter.
![]() 20 May 2012 Auto-X event after action report: http://www.moddedmustangs.com/forums...nals-site.html |
#12 | |
While the HK mag is better than a standard GI mag, putting in an anti-tilt follower in a GI mag makes it just as good as the HK. The only thing different about the HK is that the follower has slots in it to fit the anti-tilt guides in the magazine housing. $15 for Pmag or $40+ for HK mag? If you don't see the difference go look at the tourture test videos on youtube. |
#13 | |
Made in U.S.A.
2011 F150 FX4
#14 | |
94 Eaton V6
Justin |
01
I'll go for the PMAG's then. $14.20 on AIMsurplus. I'll look around for ammo, and if i don't find anything i'll just go for the 55 grain unless aim gets the 62 back in stock.
That one guy should let me know if he still has the Daniel Defense or CMMG w/DD railed uppers i want, if he has neither of them i'll just get a 1:9 spikes off their website.
Big timin' in a small town
I dont buy anything but the 1/1 twist. I like it.....
01
Damn that's craaazzyyy. 1 turn in 1 inch. But then again, drick, you do have a 1" barrel...
01
I'm looking at buying a Magpul CTR to replace the standard M4 stock. I hate the M4 stock.
What other than the CTR would anyone suggest?
Resident Bubblehead
My choices came down to the CTR or the Vltor Modstock. I checked them both out at one of my local shops and decided to go with the Modstock. The cheekweld was the biggest selling point. The Guy behind the counter also mentioned that he's tried both and the only problem with the CTR is that it tends to snag his beard. I have a beard too, but I was already sold on the Vltor anyway...
#20 | |
Token asian guy
Threads Similar to: AR15 Ammo vs barrel twist
| Can You Get 300 HP From A 2 Barrel Carb? | Gregski | Mustang II | 3 | November 26th, 2011 05:28 PM |
| 2 barrel probs | adc1986 | 2.3 Mustangs | 6 | July 15th, 2010 06:12 PM |
| Do a Barrel Roll!!!! | Smoothgrandmama | The Clubhouse | 4 | December 9th, 2009 12:13 PM |
| what ar15 ammo do u use? | mylilboostedpony | The Clubhouse | 26 | December 8th, 2009 07:26 PM |
| Oil below $120 a barrel | Regency 2007 | The Clubhouse | 47 | August 6th, 2008 11:51 AM |
