Help me select a 4 cylinder engine
Old March 1st, 2011, 03:18 PM   #1
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
We're going to build an engine to run a 30kW generator. It'll run on natural gas and have 14:1 compression. The initial engine will probably be around 2.4-2.8 liters, and must meet these requirements:
-4 cylinder
-At least 44bhp @ 1800RPM (Most 4cyl engines bigger than 2.4L will accomplish this)
Preferred attributes:
-Cheap and easily available
-SOHC, 2 valves per cylinder, non-turbo
-Low friction
-Low heat loss
-Low surface:volume
I had previously written reports on the Mazda F-series and Toyota M-series, but the F doesn't produce enough power and the M isn't a 4 cylinder and is expensive. What's going to happen is that the block from a larger engine from the family will be used with the heads of a smaller engine from the same family. This would be an easy way of increasing the compression without having to make modifications to the water jackets. Help me select an engine! Thanks!
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old March 1st, 2011, 03:21 PM   #2
Ice Cream Truck Driver
Spike Digidy!'s Avatar
85 CARB GT / 91 FI LX
Spike Digidy! is just really niceSpike Digidy! is just really niceSpike Digidy! is just really niceSpike Digidy! is just really nice
Send a message via AIM to Spike Digidy! Send a message via Yahoo to Spike Digidy!
2.3 ford (79-93 mustang/capri/cougar), u can mill the heads on these to gain ur compression without crashes valves..cheap easy, plenty available parts (new & used)
MM+Cleavage Club Founder/Member #1
*MM's Thread of the YEAR*
there was this black kid in 8th grade and i said "sup black boy?"
Old March 1st, 2011, 03:23 PM   #3
I Want A Good Speed Raping
chocolate's Avatar
chocolate is a splendid one to beholdchocolate is a splendid one to beholdchocolate is a splendid one to beholdchocolate is a splendid one to beholdchocolate is a splendid one to beholdchocolate is a splendid one to beholdchocolate is a splendid one to behold
Send a message via AIM to chocolate Send a message via MSN to chocolate Send a message via Yahoo to chocolate
asian what state are you in?
Originally Posted by lynyrd skynyrd with a very good cover done by Shinedown View Post
Oh, take your time, don't live too fast
Troubles will come and they will pass
You'll find a women and you'll find love
and don't forget that there is a someone up above
Originally Posted by sclass-hole View Post
I would never cheat on my wife (but my hand would).
Old March 1st, 2011, 03:24 PM   #4
Too Soon, Junior!
03 GT Vert
Thanks Spike! I'll dig into it.
Chocolate, I'm in Miami, FL
Old March 1st, 2011, 03:27 PM   #5
chocolate's Avatar
I asked because i saw on CL earlier when i was looking at cars there were a few engines for sale. some seemed pretty cheap.
Old March 1st, 2011, 03:42 PM   #6
amateur adult film star
sgrcltpunk's Avatar
1999 gt
to infinity and beyond
sgrcltpunk will become famous soon enough
Send a message via AIM to sgrcltpunk
Toyota S engine - Wikipedia, the free encyclopedia
performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
Old March 1st, 2011, 03:47 PM   #7
Too Soon, Junior!
03 GT Vert
Toyota S engine wouldn't produce enough power, sorry
Old March 1st, 2011, 03:57 PM   #8
old factory 2.3 fords made plenty of power for what u need, and if u mill the bastard down (fuel injected) and minimun head work, u could have u one kick ass generator...
Old March 1st, 2011, 04:56 PM   #9
Too Soon, Junior!
03 GT Vert
I looked into the 2.3 Lima engine and the non-turbo variant still may not produce enough power at 1800 RPM. I looked into the Mitsubishi Astron 4G engine family though and it seems to have potential. It'd be awesome to be able to use a Ford Duratec 25 but the valvetrain is pretty complex and it'd be expensive to convert...
Old March 1st, 2011, 05:37 PM   #10
2.3 lima? was that the platform of the late model 2.3 ford?
Old March 1st, 2011, 06:04 PM   #11
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Why not step up to a 6 cylinder? The 4.0L Fords and 4.3L Chevies are dead nuts reliable, simple to work on, easy to find and would make plenty of power.
ΜΟΛΩΝ ΛΑΒΕ
Old March 1st, 2011, 06:14 PM   #12
Too Soon, Junior!
03 GT Vert
It'd be great to use a cheap 6 and run it without modifications, but from an efficiency standpoint, it's not going to cut it. For a 30kW generator, we're looking for 30%+ efficiency, which is about 3 or 4 times that of a normal car engine. With a V6, the surface:volume ratio would be quite high, thus leading to more heat loss to the cylinder walls. This generator will operate 24/7 and go 6 to 12 months before an oil change, so even a 0.3% bump in efficiency would be monumental; and a 2.5L 4 cylinder would have about 3x-5x the efficiency of a 4.0L 6 cylinder for this application.
Old March 1st, 2011, 06:28 PM   #13
Senor Tini
2007 GT
slower than a speeding bullet
Ace417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to beholdAce417 is a splendid one to behold
Send a message via AIM to Ace417
well i went a year without an oil change in my ford 2.3L ranger so....
Nice snatch, Rob
Old March 1st, 2011, 06:29 PM   #14
Too Soon, Junior!
03 GT Vert
Without turning the engine off?
Old March 1st, 2011, 06:32 PM   #15
Old March 1st, 2011, 06:35 PM   #16
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
RDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud of
Duratec 2.3L
They're found in the Mazda 3, Fusion, Ranger, and '03-'07 Focus ST & SES. They're already flex fuel so running natural gas shouldn't be an issue. They're DOHC though which may disqualify them but they can be found for cheap.
My second recommendation is a 2.3L LIMA motor.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85!
1985 Bronco - 351W & 4WD
1986 Mustang LX - 351W build in the works!
David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly!
Old March 1st, 2011, 06:38 PM   #17
Senor Tini
2007 GT
lol no
Originally Posted by Spike Digidy View Post
it was a 4cyl ranger. i wanted it to die so i could get something new. never happened and i miss it now :/
Nice snatch, Rob
Old March 1st, 2011, 07:08 PM   #18
shoulda just dumped a 302/351...
Old March 1st, 2011, 07:12 PM   #19
88TempoGLS's Avatar
2000 Ford Contour SVT
15.2 @ 90mph
88TempoGLS has a spectacular aura about88TempoGLS has a spectacular aura about
Send a message via AIM to 88TempoGLS
Here are my suggestions. Dont fall into your requirements 100%, but they are all good engines in my experience.
2.3/2.5 HSC engine from Ford Tempo/Ford Taurus
2.0 Zetec from Ford Focus, Contour, and Escort
2.3 Duratec as stated above
2.3 Lima
2000 CSVT
03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq
1985 Honda 450 Nighthawk
70+MPG average 8200 miles and counting
Old March 1st, 2011, 07:24 PM   #20
Senor Tini
2007 GT
i didnt know anything about cars then or i wouldve.
it was gold too though
Nice snatch, Rob
Threads Similar to: Help me select a 4 cylinder engine
Bud Select 02MustangV6e9 The Clubhouse 24 August 20th, 2010 07:15 PM
engine cylinder diagram TotoGT06 2005 - 2010 12 May 13th, 2010 06:24 PM
WASSUP GUYS!!......and a few select gals! TwistedRay New Members Introductions 27 October 12th, 2008 12:43 PM
supercharged engine build. Cylinder head recomendations? Ntv69 5.0 Mustangs 7 June 25th, 2008 01:40 PM
