Any survivalists here?
Old August 14th, 2011, 05:09 PM   #1
Matt86's Avatar
03 GT
Matt86 has a spectacular aura aboutMatt86 has a spectacular aura about
I'm putting together a list for a bug out bag for natural disasters/ ZA, any suggestions?
Vortech v2 si-TiAl Q- CXRacing- still need MAF
Old August 14th, 2011, 05:11 PM   #2
good thing....i have one...and on my phone i have a digital copy of the army survival guide lol.
natural disasters...invasions...zombies...im ready
list of things i carry soon to follow
Old August 14th, 2011, 05:14 PM   #3
Bug Out Bag Checklist of Contents:
The Pack
Bug Out Bag
Your bug out bag should have enough room to carry all of your items and be comfortable to carry. If possible, Internal frame packs work best. Some bags are waterproof and provide additional padding.
Tools
Fixed Blade Knife – Gerber LMF II Infantry Knife
These have an advantage over folding blade knifes for extended survival situations. With less moving parts fix blades are more durable. Fixed blades can be used to chop through wood, can be modified to become a spear, and for serious self defense. While folding blades and multi-tool blades can do some of these things they don’t do it as good as a 4-5″ fixed blade knife. Carrying a machete or 10 inch knife is a waste of energy and adds unneeded weight in most situations.
Rope – 550 Paracord
Cordage can be made in the wild but having some in your bag can be the difference between life and death. If you need to make a shelter, a tourniquet, or make a snare cordage is invaluable. This particular cordage has smaller diameter cordage inside the larger cordage which can be used for small traps or other purposes.
Headlamp – Petzl LED with Red Filter
Headlamps are preferred over flashlights because they allow you to keep your hands free. LED bulbs last a very long time and produce a lot of light. The red light filter helps you maintain your night vision. white light contracts your pupils and takes five minutes to first adjust to darkness and 45 minutes to completely readjust . Head lamps are light weight.
Fire Starter – Swedish Firesteel – Army Model
These types of fire-starters are preferred over matches or lighters, they produce consistent sparks. You will need a nest of tender to receive the spark and kindling ready. If you’ve made traditional flint and steal or a bow drill fire you will appreciate 5,500 degree sparks these strikers produce. Be sure to carry some sort of quick start tender.
Water
Purification Tablets – Chlorine Dioxide
Chlorine Dioxide have a number of advantages over other purification methods. It’s light weight and tastes better than iodine tablets. Pump operated purifiers are heavy and can have additional risks. If you drop a pump water purifier it can crack the element, letting protozoa and harmful bacteria through the filter. An added risk to pump purifiers is storing them wet which can grow nasty things on the wrong side of the filter. The instant purification straws are handy but don’t provide protection against smaller organisms. These tablets will provide enough water purification for nearly 8 gallons of water.
Stainless Steele Water Bottle
Stainless steel water bottles have many advantages over plastic and polycarbonate bottles. Stainless canteens can boil water, be used for cooking, and are nearly indestructible. They also keep your water tasting clean. Many canteens made of plastic maintain a memory of liquids you’ve had in them. If you’ve put Kool-Aid or anything else in other plastic bottles you’ll taste Kool-Aid for months to come. In the survival settings I’ve seen these stainless steel bottles go through hell and back. They are incredibly tough and versatile. They are also easy to clean and never leak. The loop from the body to the lid can be used to snap it your bug out bag with a carabiner.
Backup Water – MSR Dromedary Bag (10 Liter)
A water bladder is preferred over adding extra water bottles because they are light and can carry a lot of water. You may consider getting the six or ten liter bags since water supplies may be few and far between. You can always use 1 or 2 liters if you don’t want the added weight and having the extra capacity may be a good idea in the long run. These bladders are preferred over plastic bladders (from Platypus or Camblebak) because they don’t get old and rigid. The MSR bags are also more puncture resistant and durable. These bags can be hung from a tree limb and provide easy access for hand washing, rinsing pots, and can even be used as a shower. You may also consider a hydration tube with a bit valve for added convenience. A drinking tube with a bite valve makes hiking much easier. It saves time by providing quick access to your water without having to stop and pull out your water bottle. When connected to the water bladder you will have two liters of drinking water accessible. The tube can also be used for a variety of survival techniques, including a solar evaporative still.Food
Food – High Calorie Food Rations
A bar like this packs a lot of energy, protein, and vitamins you need for extended hiking. Add a can of peanut butter, walnuts, jerky, trail mix, or anything with high fat and calories and you’ll stay energized. These bars have a shelf life of over 5 years, are ready to eat, and don’t taste that bad. This provides 3,600 which would provide 1,200 calories a day.
Supplies
First Aid Kit –
Tactical Trauma Kit
A first aid kit is one of the most used items in extended survival settings. This particular kit is desires because it comes with a durable carry case, moleskin, and antiseptic wipes.Quikclot will save your life if you have a deep wound that won’t stop bleeding. A SWAT Tourniquet and Suture Kit are also a good ideas.
i also have a few guns ready to head out the door with and an ammo bag...of course i've added extras then just whats on this basick BOB checklist...
Old August 14th, 2011, 05:15 PM   #4
Random Shemale Nudity FTW
MyLILPwNy!'s Avatar
2007 Mustang GT
MyLILPwNy! is a glorious beacon of lightMyLILPwNy! is a glorious beacon of lightMyLILPwNy! is a glorious beacon of lightMyLILPwNy! is a glorious beacon of lightMyLILPwNy! is a glorious beacon of lightMyLILPwNy! is a glorious beacon of light
Gun and ammo.. ALWAYS Useful
Somebody call for a really hairy plumber? Bow chicka bow wow! I came here to lay down some pipe. Bow chicka bow wow! So, I hear you have sisters. Bow chicka-who are twins-wow wow!
Old August 14th, 2011, 05:21 PM   #5
downside is weight...it's best to carry a few that have a wider range of ammo sizing...that way while on the move you have the chance to come across ammo more easily.
in fact soon im teaching my fiance how to use a few of them so if the need arises she can fire without trying to guess
on a side note...i want and AR15 lol..my friends is great
Old August 14th, 2011, 05:25 PM   #6
MyLILPwNy!'s Avatar
2007 Mustang GT
Thats good. My choice would be a 9mm. If ZA happens, wait excuse me.. WHEN ZA happens you know the military will be out and they use 9mm so that shit will be the most likely to come by. But, I would still carry a couple of rounds maybe like 2 boxes. 100 is enough and not that heavy.
Old August 14th, 2011, 05:27 PM   #7
Matt86's Avatar
03 GT
Im thinking 300 rounds of primary and 150 secondary should be good for a BOB. Know of any good places to get this stuff or do you just grab it wherever i.e. Walmart?
Old August 14th, 2011, 05:32 PM   #8
alot of it you can get in any camping store like bass pro and some of it at walmart...some of it you find online (like the paracord)....
Old August 14th, 2011, 05:32 PM   #9
MyLILPwNy!'s Avatar
2007 Mustang GT
Online
They sell completed BOB you know.
Old August 14th, 2011, 05:34 PM   #10
Online
half the time though those "completed" bags don't include certain things...plus i like putting things together from the ground up. kinda a way to know whats it it and the quality
also in the medical section of the bag include a can of solarcain and sunscreen....and yes some people here think im crazy for going to such lengths to build a BOB...but why not..it makes me feel better knowing i have something set up in place of a large spread incident that may save me or my future wife lol....right now though i'm trying to talk my lady into letting me put this in our living room when we find a home in the spring....
Old August 14th, 2011, 05:36 PM   #11
MyLILPwNy!'s Avatar
2007 Mustang GT
Guess your right. But I am good. I have acquired a certain set of skills that make me a zombies worst nightmare
Old August 14th, 2011, 05:40 PM   #12
i'll have to take pics of my BOB...gonna suck to have to unpack it for pics but if i get a chance i will
Old August 14th, 2011, 06:28 PM   #13
Matt86's Avatar
03 GT
that would be sweet. I know they sell complete kits but a lot of stuff I already have, flashlights, compass, lighters, 550 cord, 100 mph tape, etc. And from what Ive seen, you can put together your own for less than what the premade ones cost.
Old August 14th, 2011, 06:31 PM   #14
exactly and you know whats in it...and i know this sounds kinda gay but a fanny pack can go a long way for certain items you need quick access too in a pinch....
Old August 14th, 2011, 06:42 PM   #15
Samurai Vomit Magnet
Alamo Stang's Avatar
2006 Mustang GT SC Vert
Alamo Stang is a splendid one to beholdAlamo Stang is a splendid one to beholdAlamo Stang is a splendid one to beholdAlamo Stang is a splendid one to beholdAlamo Stang is a splendid one to beholdAlamo Stang is a splendid one to beholdAlamo Stang is a splendid one to behold
I have made it to 42, does that count?
sig by serbiandude
Vortech V2 HO Polished SC, Pypes long tube headers/catted X/mid mufflers, Koni Shocks/Struts, J&M Upper and Lower Control arms and Panhard Bar-488hp/425tq
Originally Posted by thrasher View Post
Penis
Enters
Toward
Ass
Originally Posted by Shelbydog! View Post
My wife has a HUGE dick!
Old August 14th, 2011, 07:18 PM   #16
Supersized Salami Swallower
Kohrs93's Avatar
00 GT
14.043@99.03
Kohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to behold
I just have a bag of viagra and take a few if anything bad happens. Then I can kill people/zombies/animals with my boner. I can eat them then too.
Black Stang Crew #Coorslight
Originally Posted by Nameless View Post
It is big...but not as big as this pic makes it appear.
Originally Posted by Dennis View Post
yea now all i need is the time to clean it and lube it and fire it.
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
Old August 14th, 2011, 07:23 PM   #17
MyLILPwNy!'s Avatar
2007 Mustang GT
You must be a SEAL or something if you can do all that killing with a toothpick?
Old August 14th, 2011, 07:39 PM   #18
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
Omg, lots of water purification tabs and a bunch of water bladders. I like any sort of modular ruck sack. The army issue ones are about the best (not the old ALICE packs, but the new MOLLE ones). Well, not the new new ACU/Multi-cam ones, but the older BDU/DCU rucks that had a separate bag for a sleep system. Those are the shit. The new medium rucks are nice too. Theyre not as massive as the MOLLE rucks but you can still fit a lot of shit in there, plus they're super comfortable even after rucking for multiple days. And 550 cord like someone else said. Ratchet strap and actual rope is good too. And don't forget batteries.
Old August 14th, 2011, 07:57 PM   #19
Matt86's Avatar
03 GT
yeah, I really like the MOLLE ruck, I was actually thinking about checking out some surplus stores and seeing if they had one. They distribute the weight pretty good.
Old August 14th, 2011, 08:02 PM   #20
We rocked the ALICE packs. Yeah they hurt after a day.
sig by serbiandude
Penis
Enters
Toward
Ass
