Question about brake boosters/master cylinders
Old September 24th, 2011, 07:25 PM   #1
Supersized Salami Swallower
Kohrs93's Avatar
00 GT
14.043@99.03
Kohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to behold
I know this is the wrong forum... but i didn't figure it would get much attention anywhere else.
Today I brought home a 92 jeep wrangler yj as a winter car. Biggest problem we have is that when you push the brake pedal, it does not return/recoil. If you pull it up with your foot it continues to work as a normal brake until you push it again. The brakes themselves work perfect. I'm thinking either a master cylinder or brake booster but I have no idea how to diagnose it and don't want to replace one then end up replacing the other as well since they're not cheap. Can anyone help me out here? I want to get it fixed so i can finally drive it!
Black Stang Crew #Coorslight
Originally Posted by Nameless View Post
It is big...but not as big as this pic makes it appear.
Originally Posted by Dennis View Post
yea now all i need is the time to clean it and lube it and fire it.
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
Old September 24th, 2011, 08:51 PM   #2
mycurse01's Avatar
2001 Mustang V6
mycurse01 will become famous soon enoughmycurse01 will become famous soon enough
sounds like no vacuum to the booster or the booster is bad.
Edit: after a quick google search
possible brake light switch (The brake light switch was seated too far in it's hole, hindering the pedal from returning all the way.)
possible bad brake booster on pedal side - The way we used to check it was to pump up the brakes and hold the pedal down. Then crank the engine while still holding the pedal down. If the pedal doesn't go down a little when it starts ... Bad booster. But that was just our way
possible binding return spring - check under dash if u have a spring and/or binding parts
2nd Edit: i just realize that the thread i got that from was yours on wranglerforums
Mods in Garage
My Youtube Channel watch my funny videos, make me daz moneyz
Originally Posted by walt1120 View Post
Listen hoe, the terminator cobra is the most baddest piece of engineering ever to exist. A man becomes baddest the moment he sits in one.
Old September 24th, 2011, 08:55 PM   #3
Kohrs93's Avatar
00 GT
14.043@99.03
That's what I'm leaning towards as well. Tomorrow we're going to see if its not getting vaccum, if it is we're going to replace it. Hopefully that fixes it... don't really want to replace the booster AND master cylinder...
Old September 24th, 2011, 09:25 PM   #4
mycurse01's Avatar
2001 Mustang V6
well if it isnt ne of them then its the master cyl. good luck my dad had a few mail jeeps (DJ body metal doors and roof) and somtimes the master cyl would allow brakes but no return due to corrosion in the master cyl. check the fluid to see if it is dirty/contaminated.
Mods in Garage
Old September 24th, 2011, 09:42 PM   #5
Kohrs93's Avatar
00 GT
14.043@99.03
Alright I'll check that as well.. thanks.
Old September 25th, 2011, 03:17 AM   #6
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
*Thinking back to my old VW that didn't have power brakes*
The pedal should return on its own regardless if you have power brakes or not.. there are springs inside the master cylinder to push the pistons/pedal back.
Question for you...
Do the brakes keep working (stopping the vehicle) until you pull the pedal up? Or does it only stop the vehicle when you have downward foot pressure, and the pedal just stick in the down position?
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old September 25th, 2011, 12:12 PM   #7
Kohrs93's Avatar
00 GT
14.043@99.03
Question for you...
they keep working until i pull the pedal up. It's kinda nice at stop lights
Threads Similar to: Question about brake boosters/master cylinders
Aftermarket master cylinders? brett22 99-04 9 May 15th, 2011 11:53 PM
Switch on brake master cylinder rod? dark star 99-04 2 October 12th, 2010 10:48 AM
brake master cylinder on big brake kit? supercharged03gt 99-04 3 August 14th, 2008 12:40 AM
noise from brake master cylinder... dansgt 99-04 3 February 14th, 2008 02:22 AM
master brake cylinder Invictus 99-04 0 February 5th, 2007 01:36 PM
