PSA: Do not buy ultima alternators - Forums at Modded Mustangs
post #1 of 14 Old October 13th, 2011, 01:50 AM Thread Starter
Imran's Avatar
I know this shouldn't be posted in the clubhouse, but I want to help you all save your precious time by exposing as many members to this as I possibly can. I have gone through 3 ultima alternators in the past year. The last one I got 2 days ago lasted only one day, and the one before that lasted 2 months. I have read many threads throughout many different forums for different cars, and all have had bad experiences with this remanufactured POS.
Pay more for an OEM alternator, don't let the lifetime warranty fool you. Yes, O'reillys does honor the warranty, and you will definitely be using it if a LOT if you get the ultima. They are huge pieces of shit.
That is all.
Imran is offline
post #2 of 14 Old October 13th, 2011, 01:54 AM
The Hammer
G.T. Rags's Avatar
you running anything besides what came in the car?
crazy head unit or subs?
i used to run 2/12's with an aftermarket deck and 1200 watt amp with no capacitor and it would kill my alternator every 10 months or so because i used the cheapo warrantied one...
ya can slap a warranty on a box of shit, it's still a box of shit
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
G.T. Rags is offline
post #3 of 14 Old October 13th, 2011, 02:09 AM
meh
Notcho's Avatar
Send a message via AIM to Notcho
Reman? There's your problem.
I bought a new ultima through AutoZone (it had the lifetime warranty too) and it worked well in my 89... It went through a frontal wreck in that car, and ended up with a 1 sq inch hole in the side of it. It still spun fine, so I put it in my '87 notch when I did the 5.0 swap from the wrecked car, and its working fine still.. that was about 50k miles ago.
Maybe I'm just lucky, but the one I have is pretty damn tough. It's been through hell.
On a sidenote, the reman ones aren't worth a damn, unless you have lots of time and patience to swap them out. When someone brings one back for a core, they send it to mexico, where they test them. They only replace the faulty component, nothing else. If it has a bad bearing, they put a new bearing and put it back on the shelf. Doesn't matter if it has 200k miles on it, they don't care, just as long as it works.
The regulator might be the next thing to fail (because its really an old unit), so if you take it back they will send it to mexico again, and (you guessed it) they will only replace the regulator, nothing else. And so on.
It's how they make money on the reman shit. It's kind of a roll of the dice, because once the faulty part is replaced, it might work flawlessly until the person sells the car, at which point the lifetime warranty is void. Then again, if it fails within the warranty, the store has to pay to replace it. But even so, what the hell? Send it back and give you another one. No real work on their behalf... you're the one who's stuck with changing the damn thing.
'87 2.3 Notch with +4 cylinder mod
Gas, Grass, or Ass.. nobody rides for free
Black Stang Crew Member #11
Notcho is offline
post #4 of 14 Old October 13th, 2011, 02:51 AM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
Find a local alternator shop and they'll rebuild it for $50-100.
Nasty is offline
post #5 of 14 Old October 13th, 2011, 03:40 AM
mxnate116's Avatar
or just hit the junkyard for a new one...when i upgraded to 3g in my fox i just got one from a newer mustang for 35$ from the local junkyard, worked great the entire time i drove the car. with the upgraded stereo and all.
and the yard i got it from offers a 1 year warranty should it fail. like you said a warranty doesnt mean much if it craps out in 2 days, but i had no problems with the one i got. i would have went the same route with my truck if the alternator didnt shit out on a sunday when the yards were closed.
mxnate116 is offline
post #6 of 14 Old October 13th, 2011, 11:19 AM Thread Starter
Imran's Avatar
Just a head unit, had subs and an an amp, took the subs and amp off and sold them.
Imran is offline
post #7 of 14 Old October 13th, 2011, 12:19 PM Thread Starter
Imran's Avatar
Well, here's the Fucking problem.
That's a Fucking fire hazard.
Imran is offline
post #8 of 14 Old October 13th, 2011, 01:21 PM
mxnate116's Avatar
looks ship shape!!
post #9 of 14 Old October 13th, 2011, 01:51 PM Thread Starter
Imran's Avatar
So I have 25% summit non piggyback underdrive pulleys, the water pump and the crank pulley, but the alternator pulley is not the 25% one, it's the stock alternator pulley. The 25% one is in my center console. Could this cause problems?
Imran is offline
post #10 of 14 Old October 13th, 2011, 07:23 PM
meh
Notcho's Avatar
The underdrive crank pulley is smaller than stock, which means it turns everything slower than the stock crank pulley would. If you put a bigger than stock pulley on an accessory, that accessory will turn even slower yet.
With my underdrive pulleys, I had a smaller crank pulley and a bigger waterpump pulley. Everything else was stock. The alternator turned a little slow at idle, and it didn't charge as much as I liked it to (ideal is 14.2 volts) ...it charged at about 12.5-12.9 volts at idle. If you gassed it, it would charge better. With the stock pulleys, it charges around 14 volts all the time.
But yes, testing your alternator with an underdrive setup could trick you into thinking that your alternator is weak. The idiots at Autozone with their fancy tester won't understand that, and they'll tell you it's bad.
Notcho is offline
post #11 of 14 Old October 13th, 2011, 08:32 PM
MM Elder/Retired Site Mod
Dennis's Avatar
yea i have never had a problem with the el cheapo refurb ultimas. sounds like its not the alternator its the owner
I can shit a human sized target at 15 feet
Dennis is offline
post #12 of 14 Old October 13th, 2011, 09:19 PM
Tini Tini Bo Bini
Ace417's Avatar
Tommy boy. Nice
What am I, some kind of nipple whisperer?
Ace417 is offline
post #13 of 14 Old October 13th, 2011, 09:28 PM
cale2006's Avatar
That is all.
Don't u just love shit parts that u have to return over and over
Originally Posted by 07 Boss View Post
Why not? I think getting stroked and blown is the way to go. Those are my plans.
MM Military Crew
SSgt USAF
gamer tag carjax06
cale2006 is offline
post #14 of 14 Old October 14th, 2011, 12:49 AM Thread Starter
Imran's Avatar
aaaassssshoooollleeee
Imran is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/clubhouse/236296-psa-do-not-buy-ultima-alternators.html
Who Makes Ultima Alternators at Askives This thread Refback February 17th, 2014 11:17 AM
