How much strain is it on a 5.0 to drive it 8hrs? - Page 3
Old November 13th, 2011, 10:43 PM   #41
TheUNZippee!'s Avatar
Fuck bearings!
Originally Posted by My Wife
Old November 13th, 2011, 10:45 PM   #42
Zip wants me
Durr4456's Avatar
2005 Mustang GT, 1967 GT
Durr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of light
Fuck bearings!
If your bearings heard you say that they'd be disappointed and maybe fall out
The day I finish paying for my mustang will be a great day. Although I'm more likely to die before it happens. Don't be stupid like me!
Zip loves my penis.
Old November 13th, 2011, 10:46 PM   #43
Bring it! I beat the piss out of mine every time I'm in it- when it finally pops, it'll be the excuse and impetus to rebuild and improve.
Old November 13th, 2011, 10:55 PM   #44
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Zip, I'm relatively sure your mod motor has slightly better oil control than our old turds...lol
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 13th, 2011, 10:55 PM   #45
Zip wants me
Durr4456's Avatar
Touché
Zip loves my penis.
Old November 13th, 2011, 10:57 PM   #46
I know. Unfortunately
Old November 13th, 2011, 11:03 PM   #47
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I drive mine down the highway a lot. A lot of weekends, I may put 300-400 miles on it, and with my 4 speed, and 4.10s, I do 57 MPH the whole time...lol. That's 2800-2900 RPMs. My engine has good bearings, modified oil galleys, and all that BS to help improve oil control, but a constant 3500 RPMs is hard on them.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 13th, 2011, 11:46 PM   #48
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
True, newer engines are built and assembled with much better precision than was possible back in the '60s and '70s.
But still, a lot of the older stuff was built from the factory with low gears and no overdrive, so by design they turned a lot of RPMs on the highway.. not just cars, but heavy trucks too. Gas was cheap, so high gears and overdrives weren't necessary. And yet the engines held up to the highway speeds, as well as people running the shit out of them..
I'd say the rod bearings really catch the most hell when you run too low octane fuel and it pings. It will ping even more when it's under a load. I've seen bearings worn down to the copper without many miles on them... newer engines have anti knock sensors, and will pull timing so that it doesn't ping.
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old November 14th, 2011, 08:42 AM   #49
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm fully aware of how old cars perform down the highway....lol. Just because people drove them like that, does it mean it wasn't hard on it? I mean I beat the crap out of mine on the street, and track, but do it with the understanding that it does reduce the life. Also keep in mind that the speed limit was 55 back then. As I said, I can do 57 and keep it under 3000. People didn't drive around at 80 MPH like they do now.
extended periods of high RPM driving is hard on bearings. That's why a lot of the big horsepower builds use a different journal. So they can slow the bearing speed for a given RPM.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 14th, 2011, 09:22 AM   #50
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
If my puny Dodge 2.0 SOHC can take 10 hours running at 2500 RPM, I think your 5.0 can handle it.
Plus as others said, these engines were designed to take a beating. We have engines here at work they run for 50 hours straight at full rated power. We're talking big engines running at WOT, 400+hp, 1500+ft-lb, and often they intentionally cause them to detonate just to see if they'll keep kicking.
And guess what. They do.
Hopefully Ford designs them to the same standards we do.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old November 14th, 2011, 09:27 AM   #51
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
^^^^^^^ that's like comparing apples to oranges.
But at 2200 RPMs, drive that thing coast to coast 10 times without stopping, and you won't have any troubles. I'm talking about high RPMs for extended periods.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 14th, 2011, 01:28 PM   #52
95Slobra's Avatar
1995 Mustang Gt
95Slobra is on a distinguished road
i plan on not ever goin over 2300rpms..hopefully il be at 2k which is my fav to cruise on since i have 373 gears. Thanks guys for all the feedback
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans
Threads Similar to: How much strain is it on a 5.0 to drive it 8hrs?
Okay, how the F do you fix a USB drive dr.gonzo! The Clubhouse 7 May 10th, 2011 12:14 PM
If you're going to drive a car like this, at least learn how to drive first... tinkerbell_too The Clubhouse 28 April 4th, 2011 11:47 PM
Let my kid drive the car... MamaStang The Clubhouse 40 September 20th, 2010 10:21 PM
L@@K San Diego Nov15th Car Show Food Drive Toy Drive for Needy Families!!! BigTedy Southwest 2 October 25th, 2008 09:16 PM
7 tooth drive gear or 8 tooth drive gear for my 98 GT manual Blue98GT Modular Mustangs 1 January 6th, 2007 07:27 PM
