? about rear main seal and leaks..
Old November 14th, 2011, 01:54 PM   #1
95Slobra's Avatar
1995 Mustang Gt
95Slobra is on a distinguished road
I recently paid over 350 bux to replace my rear seal. It was fine and just about a month later i changed my oil to synthetic. I have had car for 4 months and ran normal oil up until this point. Before i changed my oil there were no leaks. I change my oil to synthetic and my rear is leaking again
Now is the another rear main leak or because i switched to synthetic??
also i noticed oil on my front sway bar. I checked and it seems the front seal is wet also. And to an untrained eye, it seems my oil pan gasket is bad 2
This just sucks cause im going on a road trip soon and i GOTTA fix these leaks. Any ideas or advice would be great
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans
Old November 14th, 2011, 01:59 PM   #2
AnotherS197GT's Avatar
2008 Mustang GT
AnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to beholdAnotherS197GT is a splendid one to behold
iTrader: 6 reviews
Switching from regular dino oil to synthetic can clean up deposits throughout the motor that were plugging up leaks.
At least thats what I'm told.
          | COMP CAMS | FRPP | PYPES | CDC | UMI |
Old November 14th, 2011, 02:01 PM   #3
95Slobra's Avatar
1995 Mustang Gt
i heard that 2, it just weird that it leaking again with a new rear seal
Old November 14th, 2011, 02:03 PM   #4
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
It's definitely possible. Even synthetic and blends behave differently.
My Neon was doing great, a little bit of lifter chatter on startup below 20deg on the cheapest NAPA blend they sold. I decided to treat it right for once and give it some Mobil extended life synthetic, and now it chatters at higher temperatures, and for longer than it used to. It was a night and day difference after the oil change.
Moral of the story? If it works, don't change it.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old November 14th, 2011, 02:07 PM   #5
95Slobra's Avatar
1995 Mustang Gt
well how hard it is to repair the oil pan gasket and front seal? i will go back to the place that fixed the rear and hopefully they will redo it since its only a month old job
Old November 14th, 2011, 08:37 PM   #6
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
The molecules of synthetic oil are much smaller than the molecules of dino oil. The smaller molecules of the synthetic oil are able to get past very small crevices, where the larger molecules of dino oil cannot.
But this does not mean that the synthetic oil has caused the leak, it simply has "discovered" an infant leak, and regardless of what oil you are running, this infant leak will eventually grow to a size that will allow dino oil to occupy and pass also.
Synthetic oil has not been shown to deteriorate engine seals or gaskets. It is not some evil solvent that will break down sealant, or anything like that.
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Threads Similar to: ? about rear main seal and leaks..
rear main seal bandity2k00 99-04 15 March 15th, 2011 09:50 PM
Rear Main Seal 02GreyStallion V6 Mustangs 16 January 21st, 2011 01:58 PM
rear main seal Butters93 5.0 Mustangs 6 July 25th, 2010 08:23 PM
rear main seal? marks87gt 5.0 Mustangs 4 April 26th, 2007 05:16 PM
Rear Main seal 1gunner23 5.0 Mustangs 5 May 11th, 2006 11:53 PM
