Best Program For PC to PC File Transferring?
So with my new computer coming, and us still going to be using the old one for my wife's scrapbooking room, what is the best program to use to transfer data back and forth between computers? And also can this be done through my wireless network?
Hardon Enflooziast
![]() Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines, |
\/ Hidden Bewbs \/
01 Cobra Vert
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
Easiest way would be to connect both computer to the network, and use the Windows file browser to copy//paste//remote network drive.... Assuming they're both running Windows 7
![]() MM Cobra Club #66 |
eeeee!
I just use an external hard drive to transfer documents from one computer, to another, easily.
What are you looking to transfer? Theres a bunch of easy ways of doing it. Couple of things depends on the O/s and if its something simple like pictures and music, etc. Usb/external drives would be easiest.
Sent from my DROID RAZR using AutoGuide.Com Free |
#6 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
Just plug BOTH drives needed for info transer into the same machine. Boot it up and copy/paste from one to another. I do this constantly between drives, as it always gives me a perfect back-up
![]() Jazzer the meticulous one
These computers are going to be in 2 separate rooms, so I can't run a 60 foot USB cable between machines. External is a good idea. hmm.
Anything I can do wirelessly? |
Resident DJ
'01 Cobra Vert.
Just use DropBox.
Or allow sharing between the computers through the network.
How does this work Troy?
#12 | |
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
You could also install pidgin on both computers, set up a Bonjour account (really easy) and send file transfers to and from each other. What's cool about this is that it discovers people in the local network to chat with. Should work as long as your firewall allows communications between the two.
the fucks i gave today=0
yea software is retarded just set them both up on the wireless newtwork. then make a folder on each one and share it on the network and drop whatever you want in that folder and it magically becomes available on the other machine. all they have to do is put the same folder on their desktop. or just share the whole drive on the network and be done with it. computer>drive to be shared>right click properties> sharing and enable it. it would be a million times easier if both machines have win 7 sense vista is useless
#14 | ||
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
Edit: Looks like this be true according to this http://windows.microsoft.com/en-US/w...te-a-workgroup
#15 | |
95ish5.0
We on campus used Handy Backup and then transfered over to Microsoft Rich Copy. Rich copy is a lot faster, recommend it over Handy backup. just giving you two options.
#17 | ||
Senor Pointy Boots
2003 Mustang V6
Needs Track Time
#18 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Depending on you router, it may be faster with a USB. It would be even faster to actually plug the hard drive on a sata port in the motherboard. If your not worried about speed then wifi will work just fine.
The new machine is going to be hooked up to the router directly, the old one will be in the backroom hooked up wirelessly. I can't run a CAT cable all the way back there. DO I need a wireless network card for that machine?
Threads Similar to: Best Program For PC to PC File Transferring?
| Transferring TPMS? | triplettl | 2005 - 2010 | 10 | October 2nd, 2010 01:02 AM |
| Umm... 7Z file? | Dansby | The Clubhouse | 4 | April 11th, 2009 11:38 PM |
| Need to convert .MOV to .WMV or .AVI file. | Dansby | The Clubhouse | 9 | April 28th, 2008 05:17 PM |
| Question about a certain file sharing program | 06RedfireGT | The Clubhouse | 30 | September 24th, 2007 12:31 AM |
| Got another .gif file I need help with | 03 R Code | The Clubhouse | 4 | April 28th, 2007 02:40 PM |
